SolaraGuy.com • View topic - Solara Alarm System (Stock)
Postby Solaraguy026 » Wed Jul 13, 2005 12:25 pm
I am Curious the other day i armed my solaras alarm but left drivers window open when i came back i open the door from inside for some odd reason and it opened and the Alarm didnt sound? So whats stopping someone from reaching through the sunroof and doing the same?
Solaraguy026
Postby MikeATL » Wed Jul 13, 2005 1:10 pm
Good question.
Also, does the SLE have a different system than the SEs?
MikeATL
Postby Solara08861 » Wed Jul 13, 2005 2:00 pm
The factory alarm all it is is a kill switch.
To test if your factory alarm is a full alarm system the test is the window down test. Bring the windows down lock the door and open the door from the inside.
Solara08861
Postby TW85 » Wed Jul 13, 2005 8:31 pm
That is not true. The SLE, at least, has a full alarm that will sound if one of the doors, trunk, or hood is opened while armed. It will also sound if a door lock is unlocked (without opening the door) while the alarm is armed. This is all in the owner's manual and I have tested the alarm on my '04 SLE V6.
Moved on to better things...
TW85
Postby kgzero1 » Thu Jul 14, 2005 6:50 am
SE's don't come with an alarm. It comes with a theft deterent systems which simply means that you need the key with the chip to start the engine. Can't hot wire the car since the ignition is not "communicating" with the chip in the key.
If you want an alarm you have to buy one.
SLE's, on the other hand, come stock with the same thing plus an alarm.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
http://www.cardomain.com/ride/850364
http://www.cardomain.com/ride/2055035
kgzero1
Postby Down2TheC » Thu Jul 14, 2005 7:37 am
TW85 wrote:That is not true. The SLE, at least, has a full alarm that will sound if one of the doors, trunk, or hood is opened while armed. It will also sound if a door lock is unlocked (without opening the door) while the alarm is armed. This is all in the owner's manual and I have tested the alarm on my '04 SLE V6.
What he said. I didn't know about the trunk until this weekend at the Toyota show. I told someone to just pop the trunk to get to the cooler since the doors were locked but the top was down. Didn't think the alarm would go. But it did. Lesson learned.
Down2TheC
Postby dawp » Sun Jul 17, 2005 12:10 am
you can get the upgrade alarm in the se as an option which will sound an alarm,you'll just have to pay extra for it.
dawp
Postby stockae92 » Tue Aug 23, 2005 9:51 am
anybody knows if the alarm on '06 SLE V6 comes with a shock sensor?
2006 Solara SLE V6
stockae92
stockae92 - shock sensor on stock alarm? No
Postby michaels artic frost » Wed Aug 24, 2005 4:25 am
stockae92 wrote:anybody knows if the alarm on '06 SLE V6 comes with a shock sensor?
Unless changes has been made in the '06 to the alarm, which I doubt; it should be the same as the '04 and '05 models...so no shock sensor from stock unless you upgrade. :)
-Michael
Updated 06/01/12: Michael T's
