SolaraGuy.com • View topic - Paint problems
Paint problems
Paint problems
Postby silversurfer220 » Wed Jul 20, 2005 8:14 pm
Washed my car tonite and noticed the tips of the rear bumper (where the bumper attaches to the wheel wells behind the tires), the paint is coming off of there- looks like its rubbing against the body of the car and rubbed the paint off. Is this something worty of complaining about? Its going in this coming week for the rust under the hood- where the silver trim piece meets the hood. I cant believe how "fragile" the paint is on these cars. I'll try to take some pix tomorrow during the day.
silversurfer220
Postby Astro » Wed Jul 20, 2005 10:33 pm
I'd definately have it looked at, because it will become a bigger problem.
Postby crimson blades » Thu Jul 21, 2005 4:48 am
I understand your pains on paint issues. I'm having paint problems with my convertible as well. There is a metal trim peice that goes around the top on the trunk, where the third brake light is mounted. The paint is bubbling and falling off mine around the brake light. It goes in Monday for a new one. On the bright side, the dealer took one look at it and said thats not acceptable and ordered me a new one right away. Good luck with your issues
When in doubt gas it out, brakes just slow you down.
crimson blades
Postby MrMikeL » Fri Jul 22, 2005 4:36 am
I have the same problem as crimson blades. Part on order.
MrMikeL
Postby Down2TheC » Fri Jul 22, 2005 6:10 am
Must have been a bad batch flown into KY. I'm going to keep an eye on mine. No troubles yet.
Down2TheC
Postby dirtybird_1 » Fri Jul 22, 2005 7:18 am
im having paint problems too, but it seems almost like the paint itself is oxidizing. all over my bumper and trunk, there are little brown flecks of rust, or what appear to be, and the only way to get it off is to use my finernails. i live in florida but i dont live near thew ocean so it cant be the air. anybody have suggestions?
2004 Solara SE Arctic Frost
15% tint
Polk Audio DB212 12" subs x2
Kicker KX600.1 Amp
Infinity refrence 6x9 all around
Colgan Custom Bra
http://photobucket.com/albums/b82/mikeflaman
dirtybird_1
Postby slingshot » Fri Jul 22, 2005 9:02 am
dirtybird_1 wrote:im having paint problems too, but it seems almost like the paint itself is oxidizing. all over my bumper and trunk, there are little brown flecks of rust, or what appear to be, and the only way to get it off is to use my finernails. i live in florida but i dont live near thew ocean so it cant be the air. anybody have suggestions?
Rust is usually the metal oxidizing. I never heard of paint oxidizing. Doubt it is rust if you can scrape it off with your fingernails and there is paint underneath. You sure it isn't stuff from trees, etc? I'd be careful using fingernails anyway. Can you wash it off at all?
slingshot
Postby MD2606 » Fri Jul 22, 2005 6:18 pm
I had similar issues with my Sequoia and my wifes 2004 Solara also has the rust specs. I think its the metal break dust turning into rust spots. I will have the dealer deal with it.
Monday is my final date for pick up after nearly 2 weeks worth of delays.
Taking Delivery on July 25th 2005
2006 SLE V6 Solara Arctic Frost Pearl with Ivory.
Michael T's Upper & Lower Grill - First Mod
MD2606
Postby MrMikeL » Thu Aug 04, 2005 8:46 am
Had my high mount brake light trim panel replaced yesterday to fix a peeling paint problem.
MrMikeL
Postby dasiggle » Thu Aug 04, 2005 4:48 pm
Clay it using detailing clay. Will remove all foreign matter. Besure to wax or use a polymer sealant after you are done. See the detailing sticky.
dasiggle
