SolaraGuy.com • View topic - Steering/ Drivetrain Clunking
Postby silach » Sat Aug 27, 2005 5:48 pm
Hey,
Has anyone had problems with the steering controls. When I accelerate or let off the gas and brake I get a real wierd vibration and clunking sound. The dealer has already replaced the ENTIRE steering rack ($1000 for the part covered under warranty). Sometimes I get the same symptoms when I steer into a parking space or steer over a speed bump. This could be a VERY serious issue, has anyone experienced anything similiar?
Silach
silach
Postby TW85 » Sat Aug 27, 2005 8:11 pm
My universal joint has become loose according to the dealer. The replacement part is in and I have to arrange an appointment to have it replaced. Apparently it is not a safety issue but it is irritating as hell. Constant clunking when turning right and I can also feel it in the brake pedal at times.
Moved on to better things...
TW85
Postby ~Spadwaller~ » Sat Aug 27, 2005 9:38 pm
Check those pads and rotors just incase.
~Spadwaller~
Postby DatSRBoi » Sat Aug 27, 2005 10:17 pm
Hub Bearings...... I had the same Issue...
