SolaraGuy.com • View topic - How to adjust the aim of the headlight?
Postby stockae92 » Sat Sep 10, 2005 9:35 am
anybody tried to adjust the aim of the headlight before?
thanks
2006 Solara SLE V6
stockae92
Postby Lone Solara » Sat Sep 10, 2005 11:11 am
On the top of the headlight housing there is an adjusting screw right between the high beam and low beam bulbs. The screw adjusts both high and low beams at the same time; it's not possible to adjust them individually.
The adjusting screw is right under the railing that runs over the housing. There is a rubber bump to protect the hood, and right next to it there's a whole in the railing. The adjusting screw is right underneath it. The adjusting screw is like a gear on one side, and on the other side it has a 10mm (I think) head. You can use a screwdriver through the hole, or a socket to adjust the beams.
Lunar Mist Metallic
Dark Stone Interior
Black Top
K&N air filter
Lone Solara
Postby stockae92 » Sat Sep 10, 2005 12:32 pm
cool
thanks
i will try that
2006 Solara SLE V6
stockae92
Postby stockae92 » Sun Sep 11, 2005 9:01 pm
the bolt is 8mm hex :)
2006 Solara SLE V6
stockae92
Postby stockae92 » Wed Nov 16, 2005 9:03 pm
to aim the aim higher:
face the wind shield from the front of the car, look down to the hole on the cross beam where you can see the *gears*, push it to the left to aim high
reverse to aim low
both sides are the same direction to aim high and low
2006 Solara SLE V6
stockae92
