SolaraGuy.com • View topic - Drive by wire on 04+?
Postby nkx1 » Wed Sep 21, 2005 10:35 pm
Just wondering if the Gen 2 Solara's have drive-by-wire like the '03+ accords do? I quickly searched this site and looked at Toyota's site, but didn't see any mention of it.
I currently have a '99 Solara, but am interested in trading up sometime in the next year or so.
Thanks!
2001 SLE, Diamond White Pearl
nkx1
Postby indiglosolara » Wed Sep 21, 2005 10:45 pm
the gen 1-1.5 2002-2003 Solara i-4 2az motor is drive by wire.
Also the gen 2 2004+ i-4 2az motor is drive by wire.
I'm not sure about the V6 3mz motor but i think that is drive by throttle cable.
I'm sure jeff can chime in on this....
indiglosolara
Solara 2 xB
Solara 2 xB
Postby nkx1 » Wed Sep 21, 2005 10:48 pm
Thanks for the info, but yeah, the V6 is actually the one I'm interested in. I forgot to specify above.
nkx1
Postby dvdchris45 » Wed Sep 21, 2005 11:08 pm
The 04+ V6 3MZs dont use a drive-by wire/cable. The drive-by "wire" is actually an eletronical component. One which up until June 2005 suffered a lag problem which included jerky shifting in gears 1-2 and a delay in throtlle response. Lexus suffered from this as well. [now there is a fix]. So yeah thats my .02
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby FLUXEMAG » Thu Sep 22, 2005 3:49 pm
There's no throttle cable on my car. Electronically controlled pedals on all Gen2 solaras. And yes that is the source of the lag, the code that decides what it means when you move your foot was replaced on the TSB for better "feel".
1967 Karmann Ghia Coupe, Rusty White
2005 Solara SE Sport V6, Lunar Mist
2010 G37 Coupe, Moonlight White
FLUXEMAG
Postby stockae92 » Thu Sep 22, 2005 4:56 pm
would '06 needs the throttle lag TSB?
2006 Solara SLE V6
stockae92
Postby prowlerartist » Thu Sep 22, 2005 4:59 pm
what is the benefit of drive by wire?
prowlerartist
Postby michaels artic frost » Thu Sep 22, 2005 9:36 pm
prowlerartist wrote:what is the benefit of drive by wire?
http://www.worldwidewords.org/turnsofphrase/tp-dri1.htm
Lots of info on google if your bored and want to read.
-M 8)
Updated 06/01/12: Michael T's
Postby dvdchris45 » Thu Sep 22, 2005 10:17 pm
stockae92 wrote:would '06 needs the throttle lag TSB?
06a should already come with the TSB done. They put a sticker next to my "tire pressure recommendation" sticker Right by the door.
dvdchris45
Postby cablemn » Mon Sep 26, 2005 3:42 pm
Drive by wire is not the same as cable connected gas peddle. Drive by wire means it uses an electronically controlled peddle.
cablemn
