SolaraGuy.com • View topic - 0 to 60 times
0 to 60 times
0 to 60 times
Postby shaggy » Tue Sep 27, 2005 2:25 pm
Does any one know the 0 to 60 times on the solara? 4 banger auto and the 5 speed also v-6, and 06 4 banger with the 5 speed auto? :-? [/img]
shaggy
Postby Mandarinsolara » Tue Sep 27, 2005 2:46 pm
well after i installed my titan motorsports sticker im probably runnin about 5.3's or 5.4's
id like to get her down in the 4's
lol
Mandarinsolara
Postby ChargedSolara » Tue Sep 27, 2005 2:53 pm
pretty slow i'd guess..you can do a google on it and i bet you'd get an answer in less than 1 minute.
probalby in the 9's on the 4 bangers give or take a bit for the 5 speed.
v6 should be mid 7's i believe
2008 C6 LS3
ChargedSolara
Postby cRaCkeD oUt » Tue Sep 27, 2005 3:06 pm
I4 is about 8.7
V6 is about 7.4
The Solara is not a true sports car and its so damn heavy too. Anyone else experience a lot of understeer?
The TC with the same inline 4 engine is almost 1.75 seconds slower because its a LOT lighter.
Own yaH! @_@
2005 Toyota Solara SE Sport 5Spd. I4- Artic White
cRaCkeD oUt
Postby BradOwens » Tue Sep 27, 2005 3:06 pm
the 4cyl is somewhere in the 9s and the 6 is in the low 7s
BradOwens
Postby jhenty » Tue Sep 27, 2005 3:10 pm
personal tests of my 2000 5 speed:
Stock: 0-60 in 7.2
Intake/exhaust: 6.8 depending on temperatures
These are times aquired from a g-tech performance meter, so they are not perfect I'm sure but overall pretty accurate.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby theprodigy79 » Tue Sep 27, 2005 5:58 pm
Motortrend got the '04 SE 4cyl manual to 8.7 and the SE Sport V6 at 6.8 using the "manual" shift. That's the lowest I've seen the V6, most other tests show 7-7.1 (using auto). None of those tests were done with the lag fix (only applicable to the V6)...
theprodigy79
Postby zoomzoomthis05 » Tue Sep 27, 2005 6:47 pm
Mandarinsolara wrote:well after i installed my titan motorsports sticker im probably runnin about 5.3's or 5.4's
lol
dude its all about the stickers... the bigger they are the more horsepower they add.... :lol:
Silver 2005 Sport V6
Updating! =)
zoomzoomthis05
one hot solarachic
one hot solarachic
Postby Mandarinsolara » Tue Sep 27, 2005 6:57 pm
^ yes this is true
same people go crazy and start puttin stickers on top of other stickers and stuff. if one is good then more is better.
Mandarinsolara
Postby Somedude » Tue Sep 27, 2005 7:02 pm
I got this information from MSN Autos:
0 - 60 Time
(seconds) 1/4 Mile Time
(seconds) 1/4 Mile Speed
(mph) Braking 60 - 0
mph (ft.)
Toyota Camry Solara SLE - V6 3.3L (225 hp) 5A + ABS 7.14 15.50 93.50 139
Toyota Camry Solara SE - I4 2.4L (157 hp) 4A + ABS 8.94 16.90 83.80 139
here is the link: http://autos.msn.com/research/vip/Spec_ ... ab=2&sub=0
Somedude
Postby theprodigy79 » Tue Sep 27, 2005 7:08 pm
Especially "Type R" or "Vtec" stickers on a Toyota!!! They give you an extra boost!
theprodigy79
Postby DatSRBoi » Tue Sep 27, 2005 7:16 pm
theprodigy79 wrote:Especially "Type R" or "Vtec" stickers on a Toyota!!! They give you an extra boost!
Naw man.. SVT will do it for me.. WEEEEEEEEEEEEEEE
Postby TW85 » Tue Sep 27, 2005 7:24 pm
I've seen 6.8-6.9 for the V6 without the lag fix. That would impact the acceleration, IMO, because it changes the shift points and "quickness" of the shifts.
Moved on to better things...
TW85
Postby Somedude » Tue Sep 27, 2005 7:30 pm
motor trend tested the Gen 2 V6, it is 0-60 in 6.6 sec and 1/4 mile in 15.0 sec.
here are the stats for a 03 camry 4 banger manual:
Car-Stats.com Report for 2003 Toyota Camry SE
Obtained from C&D February, 2003
0-60: 8.3 Transmission: Manual
1/4 Mile: 16.5
1/4 Speed: 85
and here are the stats for the 02 camry XLE 4 banger (auto):
Car-Stats.com Report for 2002 Toyota Camry XLE
Obtained from R&T February, 2003
0-60: 8.7 Transmission: Automatic
1/4 Mile: 16.7
1/4 Speed: 84
Somedude
Postby theprodigy79 » Tue Sep 27, 2005 7:35 pm
TW85 wrote:I've seen 6.8-6.9 for the V6 without the lag fix. That would impact the acceleration, IMO, because it changes the shift points and "quickness" of the shifts.
Did you also see the 6.8s in Motortrend? I've been trying to find my source but haven't been able... The lag fix absolutely improves the 0-60... by how much, I'm not sure. But since the fix I'm actually sometimes able to chirp my tires if I hammer it from a 25mph cruise (my car has around 100lbs of audio stuff in it + 230lbs of me, and I'm riding on a new set of Michelin Pilot Sport Z rated max performance summer tires that STICK LIKE GLUE)... I couldn't do that before (or it was much harder to do so)...
Damn... 6.6s seems low, however if they were testing the car after the lag fix (or late 2005 or 2006 models) I guess it could knock off around .2s... Considering the Accord hits around those #s, I guess that's possible.
theprodigy79
