SolaraGuy.com • View topic - Transmission Slipping??
Postby MrMikeL » Tue Oct 18, 2005 6:49 am
This is worrisome. I was turning a corner in a residential area the other day, going nice and slow because of kids in the car and outside. When I accelerated coming out of the turn, the transmissin seemed to slip. The engine revved, but I wasn't going anywhere. After about 2-3 seconds, it kicked back into gear. This has happened a couple of other times in similar conditions: low gear acceleration.
Anyone else have this problem? Any ideas what it might be before I go to the dealer and have them tell me it's nothing?
MrMikeL
Postby cRaCkeD oUt » Tue Oct 18, 2005 6:11 pm
Check your AT fluid level.
Own yaH! @_@
2005 Toyota Solara SE Sport 5Spd. I4- Artic White
cRaCkeD oUt
Postby hskrsolara » Tue Oct 18, 2005 6:23 pm
I had the same thing happen with my 5 spd, yay for a new clutch...
hskrsolara
Postby zoomzoomthis05 » Tue Oct 18, 2005 6:25 pm
would get it checked out as soon as you can.. dont delay....wouldnt want N E thing bad to happen to you....
Silver 2005 Sport V6
Updating! =)
zoomzoomthis05
one hot solarachic
one hot solarachic
Postby LatinDragonXJC » Tue Oct 18, 2005 6:29 pm
Put some Lucas Transmission fluid in there....works wonders.
LatinDragonXJC
Postby FLUXEMAG » Wed Oct 19, 2005 10:19 am
I'm in denial about my transmission. I noticed in the first week I had it that there was an issue. Sometimes when I let off the pedal, the engine revs too far, then pauses, then dumps it into the next gear harshly. It gives a jerky tow rope effect.
Also, my first impression of the auto stick was that it was similar to the Porsche 911 tiptronic in the 996. This isn't a good thing. It basically means the autostick will downshift, but the upshift is not doing anything. So you shift from 1-2 and it takes another 2 seconds for the transmission to shift from 1-2. This happens on all gears. A G35C will shift immediately into the gear the auto stick selects so I know this is possible.
It's hard to get any service to act on this type of intermittent problem. I had an Acura integra automatic that had the same jerky, late shifting from new. The problem was the ECM / (also acting as the tranny controller) was shorted out by a spilled cup of coffee and shredding clutches in the automatic transmission. I found that one out after warranty expiration and two new transmissions.
FLUXEMAG
