SolaraGuy.com • View topic - Studded Snow tires
Studded Snow tires
Studded Snow tires
Postby zipobrilrok » Thu Nov 03, 2005 3:27 pm
Im having a hell of a time finding snow tires for my '04 sle v6 with the 17" rims.
Anybody have some suggestions?
btw, Must be STUDDED, too much snow and Ice next to lake erie to go without. have done so before on other vehicles will not do so again.
Thanks all
zipobrilrok
Re: Studded Snow tires
Postby joebxr » Thu Nov 03, 2005 4:09 pm
zipobrilrok wrote:Im having a hell of a time finding snow tires for my '04 sle v6 with the 17" rims.
Thanks all
I can sympathize....I live in Syracuse, NY. In our size the offerings are limited. After a lot of research, I just bought Bridgestone Blizzak WS50 studless winter/ice. I haven't seen anything availabe that can be studded. The WS50's have the best ratig for winter studless tires in our size. I've used them in other sizes and was more than pleased.
'06 Solara SLE V6
Arctic Frost/Dark Stone Grey
TRENZ Upper and Lower Billet Grilles
American Racng CASINO Polished wheels
SIRIUS Satellite Radio
joebxr
Postby Jai_Jai_Binks » Thu Nov 03, 2005 4:25 pm
buy 15 inch steelies and go for studded tires on those. This way, keep your 17's for summer driving.
Postby zoomzoomthis05 » Thu Nov 03, 2005 4:38 pm
^^^^ couldnt agree with you more... its a good idea to go that way. that way you dont mess up your 17" rims if you should happen to slide into and embankment..
Silver 2005 Sport V6
Updating! =)
zoomzoomthis05
one hot solarachic
one hot solarachic
Postby joebxr » Thu Nov 03, 2005 5:54 pm
Jai_Jai_Binks wrote:buy 15 inch steelies and go for studded tires on those. This way, keep your 17's for summer driving.
Tried to go 16" to get narrower tread width, but NO GO!
Problem is with fit over the brakes/rotors. On my 06, 16" won't fit, so stuck with 17". Don't know if 04 is same situation.
'06 Solara SLE V6
joebxr
Postby cRaCkeD oUt » Thu Nov 03, 2005 6:50 pm
Just buy chains.
Own yaH! @_@
2005 Toyota Solara SE Sport 5Spd. I4- Artic White
cRaCkeD oUt
Postby PhreakdOut » Thu Nov 03, 2005 10:40 pm
This is the way to go. I believe Tire rack has steel wheels as part of a winter package.
Word of caution: They get these from the factories in VERY limited quantities. You can expect them to be completely out of stock within weeks of the first snow storm. Don't wait.
When you check TireRack.com, look up winter tire and wheel packages for the Camry LE. You won't get steel wheels in 16" or 17", so they won't show up under the Solara. It'll probably come up with a 205/65/15 tire with a diameter of 25.6". This should be close enough to the factory diameter of you factory 215/55/17's. You could also go with a thinner tire if you have a lot of deep snow. Steel wheels run about $29 each. Awesome buy. Winter tires, $58 - $150 depending on what you want.
Best of luck, let us know what you get.
Postby joebxr » Fri Nov 04, 2005 3:26 am
Do you know if this will work? Spoke with Tirerack about my '06 and they said nothing smaller than 17" will fit. Confirmed at local dealer ship, also. Did the brake diameters change for '06 and that is why?
'06 Solara SLE V6
joebxr
Postby Mr. Slippery » Mon Nov 28, 2005 2:53 pm
Does anybody know the answer to this question? Will a 15" or 16" fit on my 04?
-MATT-
Mr. Slippery
Postby SpeedSTARs » Mon Nov 28, 2005 3:09 pm
Mr. Slippery wrote:Does anybody know the answer to this question? Will a 15" or 16" fit on my 04?
Something tells me that you have a SLE or a SE with the 17"ers. How big are your rotors front and back? This will determine you clearance condition with your rims: You will need to measure the height of the caliper + the size of your rotors (DIA). If for some event you find the specs to the rotor size matching the base solara to the SLE, your odd will be good where the 16" will get the job done. Good luck Bro. :angel:
By the way Just like PhreakdOut say, the seasons about to end on snow tire availabilty.
However, the link below is a studless tire that will fit your 17"s
http://www.tirerack.com/tires/tires.jsp?tireMake=Dunlop&tireModel=Graspic+DS-2&vehicleSearch=true&partnum=155QR7GRDS2&fromCompare1=yes
SpeedSTARs
Postby jsie » Sun Dec 04, 2005 12:55 pm
Rather than having another set of tires, what about using Spikes Spiders (this has metal studs and probably still cost less than a set of wheels)?
http://www.spikes-spiders.com/
Image Image
FYI. I normally pass a chain control area a few times a year; and, I've been happy w/ my Super Z SC135 (no clearance issue so far). BTW, I never experience the Spikes Spiders eventhough I believe spikes spider give better clearance. When deciding getting the winter traction, I chose the Super Z mainly because of the cost reason.
http://www.scc-chain.com/Pages%20Tracti ... 0prod.html
2004 Solara SE Sport
Artic Frost Pearl
2.4L I4 5-Speed MT
jsie
Postby RichD978 » Sun Dec 04, 2005 1:01 pm
Matt search townfair tire's winter wheel/tire packages. I gotten 15 inch package for 450. They might have it for you too.. Be sure to print the deal out when you bring it to the shop though
RichD978
Postby joebxr » Sun Dec 04, 2005 4:23 pm
But you drive a Gen1, correct. So the 15 might be okay. Direct from the mouth of Toyota, 2006 17" OEM, "you cannot use 16" wheels because they will not clear..." Conversation with Tirerack states same. Even went one further and talked with Bridgestone dealership...they made several calls and said, "NOPE", you can't use 16" wheels. So, I have the 17" Blizzaks and they have performed flawlessly in the snow we've gotten so far. Great traction and handling. They are noisy, however on dry pavement.
'06 Solara SLE V6
joebxr
Postby Mr. Slippery » Sun Dec 04, 2005 10:01 pm
The thing is I don't have the 17" stockies, I got the car with 18"s and they're awful in the snow. I bought some snow tires on Ebay and I'll just use the 18's I got the car with. It was pretty close to the cost of a set of steelies and tires. Just 3 inches of snow last night and I've already had it. I hate winter so much, and there's more snow to come tomorrow night. :( At least the Pats got a win tonight, it's about the only good thing to come out of December so far around here.
-MATT-
Mr. Slippery
Postby slingshot » Sun Dec 04, 2005 10:18 pm
Massachusetts is definitely not the place for summer tires in the winter. You need at least great all-seasons or dedicated snow tires.
slingshot
