SolaraGuy.com • View topic - key programming
key programming
key programming
Postby Aotoyota » Fri Nov 04, 2005 8:49 am
Anyone know how to program the transponder on the key? Dealer wants $95 for it.
Aotoyota
Postby NeFaRiOuS_SLE » Fri Nov 04, 2005 10:22 pm
Here's the instructions; and don't forget to get outside the car, walk in 3 circles under 20 seconds, then rub your stomach and pat your head at the same time 6 times.
http://www.solaraguy.org/viewtopic.php? ... highlight=
Postby michaels artic frost » Sat Nov 05, 2005 5:17 am
NeFaRiOuS_SLE wrote:Here's the instructions; and don't forget to get outside the car, walk in 3 circles under 20 seconds, then rub your stomach and pat your head at the same time 6 times.
^^^Way to help a member out NeFaRiOuS_SLE :wink: !!!^^^Nice work.
-M
Updated 06/01/12: Michael T's
Postby Aotoyota » Sat Nov 05, 2005 9:02 pm
I tried those instructions and no go. could it be the dealer gave me the wrong key? they told me that my car didnt have a transponder in the key?
and sold me the camry one.
Aotoyota
Postby zoomzoomthis05 » Sun Nov 06, 2005 12:46 am
:lol: ROFLMFAO!!! :lol:
Silver 2005 Sport V6
Updating! =)
zoomzoomthis05
one hot solarachic
one hot solarachic
Postby NeFaRiOuS_SLE » Sun Nov 06, 2005 5:29 pm
Actually, I searched deeper and found this; apparently they changed the instructions for 2002+. Why the hell do they do that? Dumbasses at Toyota make the cars easy to drive but hard to service unless you REALLY know what you're doing (e.g. the common fear of changing your spark plugs).
http://www.solaraguy.org/viewtopic.php?t=13906&highlight=transponder
NOTE: For 2004+ cars, you'll also have to tap the horn to the "Shave and a haircut 5 cents" tune upon completion the programming for each key, then when you're done, turn the steering wheel lock-to-lock 20 times in 10 seconds, then press the hazard switch 10 times within 2 seconds, then go old school and get outside your car and do the Macarena in 2 cycles within 4 seconds.
Postby Aotoyota » Mon Nov 07, 2005 8:23 am
Thanks for the help.
Aotoyota
