SolaraGuy.com • View topic - tires rubbing?
tires rubbing?
Postby rollaevo99 » Tue Nov 15, 2005 1:51 pm
Very easy! you can do it yourself..........you can use dremel to roll it, after rolling buy touch up paint to repaint.
here's my corolla to prove it I put 18"s after rolling the back fenders
I can put 4 people at the back......
Re: tires rubbing?
Postby Jack Soulfire » Tue Nov 15, 2005 4:01 pm
fromperv2pimp wrote:ive tried to get it fixed my well rubbing on my tired but every shop says they cant do it on gen 2 ... that they wouldnt be alnble to roll them they would have to cut them up and the bend them but this mite wharp the paint then i would have to repaint it is there a safe and cheaper way to roll the back fenders?????????
I tried to read that but that's some heinous grammar/sp/punctuation.
2006 V6 Solara SE Sport
Jack Soulfire
Postby michaels artic frost » Tue Nov 15, 2005 7:47 pm
rollaevo99 wrote:Very easy! you can do it yourself..........you can use dremel to roll it, after rolling buy touch up paint to repaint.
^^Oh so nice! Mad props bro. One of da cleanest rolla I've ever seen.^^
Updated 06/01/12: Michael T's
Postby Astro » Tue Nov 15, 2005 9:09 pm
Just cut them...
Postby Astro » Tue Nov 15, 2005 9:38 pm
There was a member here that had 20's and had hers cut. I did check hers out and it was cleanly done. I guess she had a hook-up.
Then, why not try rolling them? I really think that there's not that much difference between the gen1 and 2. My girl's got a gen2 convertible. When I did mine, I just used a metal pipe and pushed up on the lip. I did it like in stages, working my way around. If you do it in small increments, you shouldn't crack the paint. I've got the edge of the lip almost touching the inner fender well. It took some time, but now I've got no rubbing issues - plus it was free. :D Make sure and place something (like a towel) between the lip and pipe.
Postby KansasSolara » Tue Nov 15, 2005 9:50 pm
Just pay the $600 and be happy with your wheels, or sell the wheels and go back to stock :o
Just do it baby!
KansasSolara
2006 SLE V6
http://www.cardomain.com/ride/2178340
KansasSolara
CowTown Solara Driver
Postby indiglosolara » Tue Nov 15, 2005 10:34 pm
I had mine cut in the rear.. no problems at all. If the shop knows how to do it you shouldn't have any problems. Also they used a sealant after they cut mine so that it doesn't start rusting from that area. I've had them cut for about a yr now.
im running 19x8.5 wheels with 235/35 tires.
If you need more help just hit me up via PM.
the shop i went to is TWS. The Wheel Supply. Tell them Kenny from Kallusive sent you thier. I paid $40 bucks each side. if you want to meet up and see how mine look just let me know
indiglosolara
Solara 2 xB
Solara 2 xB
