SolaraGuy.com • View topic - 04 brake pads
04 brake pads
Postby PhreakdOut » Wed Dec 28, 2005 3:35 am
Are the pads from Toyota or an aftermarket brand?
Postby FLUXEMAG » Wed Dec 28, 2005 9:09 am
Autozone generic brake pads are probably used on 100 models of cars. It really has nothing to do with the 04 and 05 model Solara. Same thing for radiators, they find a part that's pretty close to the same size. You can buy toyota brake pads, they don't have to be TRD. It will be more than AZN still, but seriously, they stop your car.
FLUXEMAG
Postby MrMikeL » Wed Dec 28, 2005 10:45 am
I've never had much luck with aftermarket pads, so I always use OEM pads - until I have to change rotors, then I get a matching set of rotors and pads.
MrMikeL
Postby NitrousFlare » Wed Dec 28, 2005 7:00 pm
not yet anyways
NitrousFlare
04 brake pads
Postby dale5599 » Thu Dec 29, 2005 5:59 pm
yeah... i ran into that same problem. i had to go to crazy spots to find the right pads that fit, while my car sat at my buddy's crib in the air... dont understand either...
dale5599
Postby dale5599 » Fri Dec 30, 2005 4:47 pm
i had to use the brake pads for the 05 solara which, if i remember correctly, were about .5 inch longer... so that was that. at least now i know in the future which brake pads to use... FYi- after market pads, not toyota
dale5599
