SolaraGuy.com • View topic - "range" error
"range" error
"range" error
Postby mauleskyrocket » Mon Jan 02, 2006 3:09 pm
I am speaking of a new 06 solara cvtble. The car averages 24-25 mpg. Yet when I fill it --- it always says 284 miles for "range". Obviously this is incorrect. Since I know the mileage by odometer divided by gallons added---what is wrong? a defective computer or a software issue? Thx.
mauleskyrocket
Postby HKSV6SLE » Mon Jan 02, 2006 9:31 pm
maybe defective car? :drinking: :drinking: :drinking: :drinking:
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Yanks0114 » Tue Jan 03, 2006 10:30 am
Sounds like a defective trip computer - take it to the dealer
BTW, I'm moving this to gen 2
Postby cklinh » Tue Jan 03, 2006 10:36 am
It says 284, but it counts down right?
I think if you read through all the posts about the range display, you'll find that most people find it very inaccurate.
It is funny that it always goes back to 284 though. Exactly how many times has it gone to 284? (and not just around 284)...
Mine greatly varies depending on how I drove the last few tanks... if I had done mostly city driving, the range, upon fillup would be around 280. if I had driven mostly freeway, the range goes up to 330-ish (that's not to say that that's the mileage I'm actually getting). The range display automatically corrects itself as you drive (ie, it doesn't necessarily go down 1 mile for every mile you drive).
Take it for what it is, that is, another warning for when you're low on gas.
cklinh
Postby theprodigy79 » Tue Jan 03, 2006 11:19 am
cklinh wrote:It says 284, but it counts down right?
Agreed... Mine never goes much above 300, however I usually get closer to 350-400 miles on a tank depending on my driving... I usually put on a good 25 miles when it says "0"...
theprodigy79
Postby kingkakyle » Wed Jan 04, 2006 4:10 am
really? after having my car for a couple months my range says 350 or more
i think it depends on how much ur car says u get MPG....then they multiply that and watever.....but ya its very innaccurate
2005 Toyota Solara V6 SLE
Postby dchev » Wed Jan 04, 2006 10:40 am
I can go 400 miles before my light comes on. My average MPG is 26miles per gallon now, and 26-29 miles per gallon during spring, summer, and fall.
However, I bought the car in Chicago, CarMax, and drove back to Charlotte, NC. So I might have broken into the engine for better milage?
:lol:
dchev
Postby cklinh » Wed Jan 04, 2006 11:05 am
These are all V6's?
cklinh
Postby dvdchris45 » Wed Jan 04, 2006 3:04 pm
Mines would top out at 265miles but after I disconnected the battery and reconnected it, it jumped to 300 miles..this was of course a long time ago when my buttong work :-( lol
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby linmk2 » Wed Jan 04, 2006 6:59 pm
I bought a new 06 convertible and posted the same question. My display does change at fill up, but does not reflect a mileage figure even close to what it should be. I'm not going to take the car in just for that, but if I have to take it in for a larger problem, I'm going to mention the range error. I've owned a number of cars that have this feature, and they were more accurate than the Toyota's display.
Howard
linmk2
Postby MCOjerry » Wed Jan 04, 2006 7:29 pm
I have an 06, V6 convertible and when i fill up, the range goes to 384mi. I don't ever trust those though...it's just a guestimate. Your driving habits could make it VERY inaccurate.
Postby Down2TheC » Thu Jan 05, 2006 2:41 pm
If you're resetting your avg. mileage, then it has to guess. Any time it's guessing it goes conservative. You'll find that it may stay the same for a while or even go up once it has better figures on the mileage.
If you don't reset your avg. mileage, then it should show up fine when the tank is full.
Down2TheC
Postby linmk2 » Thu Jan 05, 2006 6:37 pm
Down, that's interesting. Reseting the AVG on my other cars did not affect the Range readings, but I'm going to try that the next time I fill up and see what happens. Thanks.
Howard
linmk2
Postby linmk2 » Sun Jan 08, 2006 12:57 pm
Just filled up today and did not reset my Avg MPG. Once I filled up, I scrolled to "range" which was showing 9. I started driving and after about .02 of a mile the display flashed to 351. That is the highest reading I've had thus far. This reading is much closer to an actual range. Once the range number of 351 appeared, I scrolled to AVG MPG and reset the AVG to 0. I then went back to range, and the reading of 351 was holding. Down's suggestion of not resetting the AVG MPG after the fill-up, seems to work!
Howard
linmk2
Postby Down2TheC » Tue Jan 10, 2006 5:34 am
And I noticed that when I topped off, I got 284 for an initial guess too. Must have a default mpg in the firmware to use in the calculation any time the mpg is less than some magic number number.
Down2TheC
