SolaraGuy.com • View topic - Correct tire pressure
Postby Dishon » Wed Mar 08, 2006 6:25 pm
i got a 04 sle with 18 inch bbs wheels my question is what is the correct tire pressure i should use .....1 on the car door panel says 32 psi and on the tire it says 35psi????
Dishon
Postby Somedude » Wed Mar 08, 2006 6:30 pm
go pump it up to 35 psi since you are rolling on large wheels, you don't want to have too little air and risk bending the wheels over pothholes. Don't pump too much air though as that is not good for the suspension or the tires.
recommendation:
35 psi
Do not pump over 35 PSI.
Somedude
Re: Correct tire pressure
Postby interceptor_1972 » Wed Mar 08, 2006 8:25 pm
Dishon wrote:i got a 04 sle with 18 inch bbs wheels my question is what is the correct tire pressure i should use .....1 on the car door panel says 32 psi and on the tire it says 35psi????
Are these stock wheels or aftermarket? The pressure indicated on the door panel indicates the ideal pressure under stock conditions, based on stock wheels/tires... the one on the tire indicates the maximum rated for that tire. If those are stock wheels/tires, I'd go with the ideal recommended pressure that Toyota indicates on the door panel.
2004 Solara SLE V6
Arctic Frost Pearl
interceptor_1972
Postby Dishon » Wed Mar 08, 2006 8:31 pm
actually there the optional wheel package for the 04 solara but there are only recommended psi's for 16 and 17 inch wheels
Dishon
Postby interceptor_1972 » Wed Mar 08, 2006 8:40 pm
Dishon wrote:actually there the optional wheel package for the 04 solara but there are only recommended psi's for 16 and 17 inch wheels
Optional as in from the factory? Or optional as in from the dealer? If it came as a factory option, then the posted tire pressure on the door plate shows the correct pressure for the wheels that shipped from the factory... if, at any point however, if the wheels were changed after being shipped from the factory, then the tire pressure in the door plate is no longer effective...
2004 Solara SLE V6
Arctic Frost Pearl
interceptor_1972
Postby theprodigy79 » Wed Mar 08, 2006 9:03 pm
33-35lbs should do you well
theprodigy79
Postby Dishon » Thu Mar 16, 2006 2:47 am
its an option from the factory
Dishon
Postby dude » Thu Mar 16, 2006 1:39 pm
i am using 37-39 psi on my stock 17's. have the trd springs and rsb. i would prefer the set up to be a few notches stiffer so this helps. i little more road noise and little more bumpy but i get a little more control. with the 18's maybe there is less sidewall deflection and would have greater path control.
dude
Postby Assyrian » Thu Mar 16, 2006 1:56 pm
go with 35 psi.
-Edgar
A noobie with an 02 SEV6 MTX
Assyrian
Postby geminiz » Fri Mar 17, 2006 9:20 am
I thought we are suppose to go by what the door panel says? It says that also in the manual book.
For stock 16s, it is 29 psi
For stock 17s, it is 32 psi
2006 Solara SE (2.4L w/5 speed automatic)
Lunar Mist
geminiz
Postby NeFaRiOuS_SLE » Mon Mar 27, 2006 11:54 pm
Not always. I have a Gen1, but it says something to the effect of raising the PSI from 32 (?) to 35 in locations where speeds over 100 mph are legal, and it is a 15s/16s car, so however that works...
