SolaraGuy.com • View topic - Condensation in the headlight?
Postby sgunitkc » Tue Mar 28, 2006 4:47 pm
Does anybody have the problem of having condensation inside the headlight casing? For some reason only my right headlight has condensation inside. Thanks.
sgunitkc
Re: Condensation in the headlight?
Postby dude » Tue Mar 28, 2006 5:14 pm
sgunitkc wrote:Does anybody have the problem of having condensation inside the headlight casing? For some reason only my right headlight has condensation inside. Thanks.
if you have not had any accidents, this should just go away on its own as weather warms. or try using your night time lights to try and warm inside to evaporate. sometimes, moisture just builds up in there and is not much of an issue.
dude
Postby Biggi_e » Tue Mar 28, 2006 9:20 pm
f u want to go the hard wayif this continues, bake open your headlight of use a heatgun, open it up and reseal it with clear silocone sealan. mak sure you clamp it together very tight during the drying process.
Postby MikeATL » Wed Mar 29, 2006 7:37 am
Uh, I would take it to the dealer if you still have any warranty left. They should replace it.
If don't, you can buy those sillica packets and stick them in there to try and absorb the moisture.
If your headlight is leaky, I dont think its going to get any better. Every time it rains your headlight is going to get water in it.
MikeATL
Postby dude » Wed Mar 29, 2006 11:12 pm
i heard some dude was using a heat gun to evaporate moisture and it blew up in his face. cant really imagine that could happen but i remember hearing that once and he must have been really heating it and there must have been alot of moisture in it. just fyi, dunno if true....
dude
Postby sgunitkc » Thu Mar 30, 2006 12:52 am
i guess ill try taking it to the dealer first cuz im still under warranty and see what happens. thanks guys
sgunitkc
Postby Solara08861 » Thu Mar 30, 2006 9:00 am
I had the same problem took the car to the dealer and it was replaced.
Solara08861
Postby alan8888 » Fri Mar 31, 2006 11:44 am
ya..me....i have 6 headlight, and 3 of the headlight...has little crack on it inside the chrome part just under the output of the projector
alan8888
Postby onefiend » Fri Mar 31, 2006 9:13 pm
Park it under the sun, worked for me.
2007 Camry SE V6
onefiend
Postby WTF?? » Sat Apr 01, 2006 12:21 am
onefiend wrote:Park it under the sun, worked for me.
thats only if you HAVE sun.... if its rains constantly youre assssed out
but what the condensation leaves behind makes the inside of the housing ugly!!!
if you can get it replaced... go for it!!!!!!!!!!!!
Retired... its been fun Image
WTF??
