SolaraGuy.com • View topic - Can't Start Car.
Can't Start Car.
Can't Start Car.
Postby chowman4ever » Thu Mar 30, 2006 1:21 pm
the engine wont start and i checked all the fuses and its good. also the car is only 2yrs old but it could b a battery problem. there is no cranking sound when i turn the key and radio doesnt work when it is in the on position. however i did check the fuse in it and it appears to b fine.
chowman4ever
Postby sahuddleston » Thu Mar 30, 2006 1:25 pm
battery - jump it and see what happens
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby MikeATL » Thu Mar 30, 2006 1:30 pm
Its the battery.
MikeATL
Postby geminimouse » Thu Mar 30, 2006 1:41 pm
and if it's not the battery, check the main 40amp fuse..
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Somedude » Thu Mar 30, 2006 1:49 pm
This thread makes me think about my car's battery condition.
my car is almost two years old, should I change the battery (it is the battery that came with the car)?
one question, what tools do I use to check car batteries?
Somedude
Postby geminimouse » Thu Mar 30, 2006 1:58 pm
Somedude wrote:This thread makes me think about my car's battery condition.
ur battery should last another year or so..
a voltmeter and on my stock battery there's an indicator on the top
08 Accord Coupe
geminimouse
Postby theprodigy79 » Thu Mar 30, 2006 2:22 pm
My battery was shot after 8 months... The indicator still showed "green", but when I took it into Advance Autoparts to have it pressure tested it smelled like rotten eggs. I do have a rather high draw stereo system, but it can still happen either way...
theprodigy79
Postby MikeATL » Thu Mar 30, 2006 2:32 pm
make sure you check your water levels.
MikeATL
Postby cklinh » Thu Mar 30, 2006 2:58 pm
Off topic... but this thread got me thinking... we really haven't heard from silversurfer220 in a while, right?
cklinh
Postby PhreakdOut » Thu Mar 30, 2006 2:59 pm
If this happened "all of a sudden" then it sounds like the ground to the battery.
Was the battery loose in the tray?
Postby Mandarinsolara » Thu Mar 30, 2006 3:02 pm
haha, i dont even use an air filter and i have better reliability
Mandarinsolara
Postby geminimouse » Thu Mar 30, 2006 3:27 pm
Mandarinsolara wrote:haha, i dont even use an air filter and i have better reliability
08 Accord Coupe
geminimouse
Postby lilmike2069 » Thu Mar 30, 2006 3:34 pm
If you have a transponder key, then try using your "valet" key to see if it will start. The transponder could be bad in your key, and the car wont start if its bad. Its a safety feature so that if someone tries to jack your car... they cant
lilmike2069
Postby Down2TheC » Thu Mar 30, 2006 4:55 pm
The systems would power up without the transponder I think. Just no cranking.
(And yes, silversurfer220 dissappeared once dude pointed out his reality to the masses. Otherwise he surely would have posted here. 8) )
Down2TheC
Postby MCOjerry » Thu Mar 30, 2006 5:22 pm
gemini...don't ask....
