SolaraGuy.com • View topic - PLEASE HELP ASAP , so i don't trade it in tomorrow
Postby bestfromnw » Thu Mar 30, 2006 11:38 pm
I just purchased the car two days ago, and i just noticed weird issue:
when i start the car after it has been sitting for 5-6hrs, it idles weird - ti goes 1500rpm - 1300rpm - 1500rpm - 1300rpm every second then it drops to 1000rpm and does the same thing but 1000rpm - 700rpm - 1000rpm every second.... then when its warm it idles normal.
By the way - car runs perfect and drives very nice - i'm not sure if its normal or not but i have no check engine light and it drives extremely nice - i love it, but this concerns me.
Oh yea, when i drive it for first 10 minutes for example if i go down hill 40mph and when i put it in neuteral (its manual) it does 1000rpm-900rpm every second... when i'm in gear - its perfect.
thank you for the replies.
I still have one day to trade it back in in case if i got the poopy one :agrue:
but i really dont want to :oops:
<b>2004 Solara SE Sport 5speed</b>
bestfromnw
Postby dude » Thu Mar 30, 2006 11:45 pm
how many times and for how long does it do this up/down thing?
dude
Postby bestfromnw » Thu Mar 30, 2006 11:46 pm
on idle only when its cold... you wouldn't notice it unless you look at tach
bestfromnw
Postby bestfromnw » Thu Mar 30, 2006 11:47 pm
oh yea, it does it every morning :(
bestfromnw
Postby PhreakdOut » Fri Mar 31, 2006 2:38 am
Have you done the intake trick from the tutorials? Seems like something is up with your IAC. Doing Doc John's bypass may help.
See this thread: http://www.solaraguy.org/viewtopic.php?t=15925
Postby krawzyazn » Fri Mar 31, 2006 2:43 am
dude is it a cold start?
Postby bestfromnw » Fri Mar 31, 2006 11:22 pm
I think it has a cold start cause it takes about 1-2 min to warm up.
COULD it be caused by dirty air filter?
bestfromnw
Postby Somedude » Fri Mar 31, 2006 11:26 pm
when I start my car on a very cold day, like on a 30 degrees fahrenheit day, my car has a sound, but after it warms up, it is normal.
I wouldn't let my car idle for 5-6 hrs, that is not a good thing to do, it does nothing but waste gas.
You should take it to the dealer if you are not sure.
Somedude
Postby dominoSLEV6 » Fri Mar 31, 2006 11:57 pm
That's just when your engine is cold it idles higher to warm up the engine faster. The hovering of RPMs IMO has somethign to do with the alternator, sometimes you'll hear that little click and RPMs changea tiny bit.
Don't worry, your car is normal.
-chris
dominoSLEV6
Postby Turbosolara » Sat Apr 01, 2006 1:18 am
do you still have warranty?
have you done engine oil change recently? if so, what grade of oil did you put in?
Postby NeFaRiOuS_SLE » Mon Apr 03, 2006 12:00 am
Question:
Turbosolara wrote:do you still have warranty?
Answer:
bestfromnw wrote:I just purchased the car two days ago, and i just noticed weird issue
Postby Down2TheC » Mon Apr 03, 2006 5:07 am
Point it out to the dealer. My '04 has a steady idle whether boosted for cold start or after when warmed up. But I'm V6. Any I4's out there wanna testify? Doesn't seem normal to be hunting like that. If it's an issue it's small no doubt, but make the dealer answer for it anyway.
Down2TheC
Postby tacti » Mon Apr 03, 2006 5:14 am
I have I4 and do that up and down RPM thing when it is cold.
I haven't checked the tachometer, but could tell by the engine sounds goes up and down.
I think as dominoSLEV6 said, it does that to warm up the engine.
no worry and enjoy your solara!
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby bestfromnw » Tue Apr 04, 2006 11:28 pm
i was told by few mechanics that its engine heater thingy... so no worries ;)
bestfromnw
