SolaraGuy.com • View topic - White Smoke coming out of the Exhaust
Postby LOGIC777 » Sun Apr 02, 2006 6:37 pm
For like 3 months I have been experiencing way too much white smoke coiming out of my exhhaust when the car is cold started but also when it's hot in the day time although a little it doesn't seem right either time.
I swithced to the K&N air filter 3 months ago, I think that it might have to do something with it?
What do you guys think?
I am concerned with a blown Catalytic Converter...
LOGIC777
Postby 2kSoulara » Sun Apr 02, 2006 7:01 pm
Dude! go to the dealer and let them check the engine! That happened to my car and it was oil sludge! They supposedly know about this problem with our cars. they practically rebuilt my engine for free as a one time deal otherwise it's a $3K job. take it to the dealer ASAP before it gets worse
2kSoulara
Postby TRD MCV20L » Mon Apr 03, 2006 12:52 am
White smoke is coolant burning.
TRD MCV20L
Postby Turbosolara » Mon Apr 03, 2006 1:01 am
constantly check your coolant level. if you do not lose any coolant, than it just too much condensation in your exhaust pipes.
Postby LOGIC777 » Mon Apr 03, 2006 3:30 am
Coolant Level seems to be fine.
Why would it be too much condensation?
LOGIC777
Postby Down2TheC » Mon Apr 03, 2006 5:00 am
Is this perchance your first winter with the car? Might be normal stuff, but let the dealer check when you go in next.
White smoke can be normal condensation, coolant, or oil. With oil it would send out a couple good puffs at start up then mellow out. Coolant would probably be constant regardless of the temp, and you can smell it. Condensation is all looks and should coincide with the temp. More in the cold, less when hot.
Down2TheC
Postby Sebas007 » Mon Apr 03, 2006 5:03 am
LOGIC777 wrote:Coolant Level seems to be fine.
Bull's eye !! You are from which part of North America ? I mean...it's normal that in cold temp you see a lot of "white smoke"...if you are not accustom to cold weather then you can conclude that there is a problem...if you are accustom to cold weather and you really find that there is way too much "white smoke" go check it aat the dealer.
Postby LOGIC777 » Mon Apr 03, 2006 5:43 am
Yes, it is my first winter with the car.
I am not sure what to made of it.
Could it be that K&N air filter I put in there?
I might have put it backwards :(
The thing is that most cars I see like outside work do not have this issue at all, maybe a little but that's it.
I am from South California and the temp is the the low 50's when it mostly does it.
LOGIC777
Postby Sebas007 » Mon Apr 03, 2006 7:13 am
LOGIC777 wrote:Yes, it is my first winter with the car.
low 50's is mild enough...you should not see a lot of "white smoke". It Should happens around 32...
about the K&N filter...it should fit perfectly in the box and there is no problem there...if you rettach everything well after...
I don't know what it can be else then that.
Postby LOGIC777 » Mon Apr 03, 2006 11:40 am
The box is well fastened.
So no chance that I could have put it there backwards or it doesn't matter which way it goes?
I will be checking with the dealer because it's just way too much and like i said most cars around don't do the same.
LOGIC777
Postby Turbosolara » Mon Apr 03, 2006 11:57 am
if it only happen when you start up the car, i do not think there is any problem.
if it happens when you step on the gas, than you might have blown head gasket.
it is normal at CA in cold weather
Postby trdkamuri51o » Mon Apr 03, 2006 1:00 pm
ill clear this up for you..
what it is: valve guide seals
why: they are starting to go bad.. what happens is when you turn off yoru car there is still oil in that general area.. when the seals go bad just a bit gets by and into the combustion chamber.. now you said it was white right??? WRONG look closely you will see a hint of blue... thats oil burning off... more than likely this is less than a pea size.. remember a little oil burns a long way..
if you hate this you can tear it apart and replace them and waste money.. or you can do like i did and just live with it as it does no harm...
trdkamuri51o
Postby dude » Mon Apr 03, 2006 10:28 pm
oil burns blue. too rich runs black. white is evaporation of h2O. would have to be pretty severe head gasket leak to blow excessive white smoke. do you drive mostly short trips? could be evaporation of moisture in exhaust system that evaporates only when temp gets above certain point. does this condition go away after 30-40min of constant driving? as Turbosolara said, if head gasket, you will see coolant level dropping and will find your oil to be a kinda like chocolate milk.
dude
Postby LOGIC777 » Tue Apr 04, 2006 1:14 am
I forgot to mention it does it at cold startup severe.. and light when it's hot.
But goes away after like 5 minutes of driving or when the temperature needle raises half-way.
I would incline towards condensation but why is it so much?
I still haven't taken the car to the dealer but i am getting tired of this.
Thanks to everyone for the feedback.
LOGIC777
Postby kingkakyle » Tue Apr 04, 2006 1:51 pm
well if ur in LA like me the temp has gone way down lately
so if i read correctly u said it goes away after the car warms up, to halfway between cold and hot it should be fine....jst the cold weather lately here making it more severe
