SolaraGuy.com • View topic - blinking yellow light
Postby Dekanas » Fri Apr 21, 2006 3:56 am
What does blinking yellow light in the dash means?
Something like circle with exclamation mark inside.
It seems to be low tire pressure or low oil level?
Dekanas
Postby tacti » Fri Apr 21, 2006 5:10 am
I think it is low tire pressure.
make sure that you have correct tire pressure, and then reset the pressure sensor.
i think it was on the manual somewhere.
it happened to me before, but after i reset, i haven't have any problem.
tact
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby gone » Fri Apr 21, 2006 6:51 am
yea its the tire pressure. i had a issue with that like 2 months ago, i didnt know wat it was either.
gone
Postby Dekanas » Sun Apr 23, 2006 12:29 pm
oh yes, may be.
I have changed two tires with bigger ones. So that the reason.
Pressure is ok. I'll try to reset the computer.
Thanks.
Dekanas
