SolaraGuy.com • View topic - New Tires
New Tires
New Tires
Postby cablemn » Fri Jun 09, 2006 3:09 pm
Just wanted to share...purchased a new set of Kumho Solus tires based on the reviews at tirerack and the treadwear rating. I bought the straight replacement size. These tires are great. Smooth as silk. Handles great in wet and dry. NO NOISE. A great buy at $122.00 installed with high speed balance, epa surcharge, and tax. Got em from a local tire guy which is sometimes better than online. Your local guy can sometimes cut you some slack on a warrantee issue. Hope this helps someone.
cablemn
