SolaraGuy.com • View topic - ODO - miles or KM?
ODO - miles or KM?
ODO - miles or KM?
Postby Yehor » Tue Jun 13, 2006 7:58 am
i changed miles to KM using 2 buttons on clock
question: odometr will be in km also or only in miles?
Yehor
Postby Sebas007 » Tue Jun 13, 2006 10:03 am
I didn't try it on mine...because it was already in km.
What they you in the owner manual ?
It will be very easy to see the difference if it changes.
Postby NeFaRiOuS_SLE » Thu Jun 15, 2006 10:09 pm
You might want to try doing this again, but pay close attention to the odometer while doing it. If it adds almost half, (e.g. if you have 1000 miles, you'll have 1609 KM), then you might have changed it. If not, it would be staying in miles. I remember you buying a Solara and exporting it to Ukraine, but did you buy it from USA or Canada? If you wanted KM from the get-go, it would've been better to buy it from them.
Postby angelo » Fri Jun 16, 2006 10:58 am
the 2 buttons would not change the odo at all.
angelo
Postby Biggi_e » Fri Jun 16, 2006 12:57 pm
hey yehor, how is your car holding up in ukraine?
Postby Yehor » Sat Jun 17, 2006 12:40 am
car was exported from usa.
2400 miles at all, 4 scratches and 1 damaged tire(damn dam damn, so hard to find tires). but nothing big.
left door was repaired myself using knife.
12.5 liters per 100km (95 petrol)
and... I am not alone :)
Yehor
Postby jusTce » Mon Jun 19, 2006 10:33 am
When you press HH:MM buttons simultaneously, that will change the following:
1. Consumption from MPG to L/100km - both average and instantaneous
2. Driving range from miles to km.
3. Temperature from degrees farenheit to Celsius
As you may have noticed, all those changes happen on the multi-information display, none on the main panel.
If your car was made for US market, your odometer and two trip meters are and always will be in miles. If your car was made for Canadian market the odometer and trip meters will be in kilometers. This does not change.
jusTce
Re: ODO - miles or KM?
Postby harntabo » Fri Jun 18, 2010 12:24 pm
Thank you, that whas a really quick fix! added value to my "Swedish Solara" :-)
harntabo
