SolaraGuy.com • View topic - power windows
power windows
power windows
Postby scLara626 » Thu Jun 15, 2006 5:27 pm
i had my car for about 3yrs now and its starting to feel like my windows are slugish. They dont seem to go as fast down or up and in the middle of going down it kinda sutters.? Hows everybodies and is this warranty status?
scLara626
Postby iinokturnolii » Thu Jun 15, 2006 5:53 pm
get some "silicone spray" and spray it between the sides of the windows. it will make em like brand new again.
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Postby kgzero1 » Fri Jun 16, 2006 7:03 am
Sides?
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
http://www.cardomain.com/ride/850364
http://www.cardomain.com/ride/2055035
kgzero1
Postby rossman945 » Fri Jun 16, 2006 7:48 am
Where can you get the sillcone spay? Do you have to take the door panel off to spray? Won't the sprayed door keep smeering all over your windows?
rossman945
Postby steve-o » Fri Jun 16, 2006 8:10 am
Like the man said spray some silicon down the sides near the rubber stripping. try a little at first, then more if needed, it WILL help. Sillcon spray is available at any hardware, home depot, etc. type stores
steve-o
Postby MikeATL » Fri Jun 16, 2006 8:17 am
will WD40 work?
MikeATL
Postby QuickSEV6 » Fri Jun 16, 2006 8:41 am
MikeATL wrote:will WD40 work?
It may work at first, but not for the long term.
Just as a side note, WD40. is not designed to be a lubricant.
It is, in fact, a Water Deterent. It was the 40th attempt at the formula when NASA was finally pleased with the results. Hence, WD-40.
You learn something new everyday, don't you?
Postby PXLpainter » Fri Jun 16, 2006 9:06 am
Rub a little bacon grease or Crisco on the edges of your windows before you roll them down. Not only does it lube 'em a bit, it smells like breakfast every time you get in your car! :D
Postby kgzero1 » Fri Jun 16, 2006 10:18 am
steve-o wrote:Like the man said spray some silicon down the sides near the rubber stripping. try a little at first, then more if needed, it WILL help. Sillcon spray is available at any hardware, home depot, etc. type stores
Ah, I see. The sides!
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
kgzero1
Postby shocar4 » Fri Jun 16, 2006 10:25 am
i had a truck that was doing that and i had to clean the tracks with some silicone lube...man they worked faster than ever!!
shocar4
Postby Jai_Jai_Binks » Fri Jun 16, 2006 10:57 am
shocar4 wrote:i had a truck that was doing that and i had to clean the tracks with some silicone lube...man they worked faster than ever!!
^^ what he said.
Learn how to remove the door panal, and then lube the tracks (teeth or whatever some people call them). At times its just dusty or dirty and just needs a can of compressed air to clean it...then followed by lubrication! Some of you all have intresting ideas...bacon grease...LOL
Postby PXLpainter » Fri Jun 16, 2006 1:11 pm
MMMMmmmmmm.... baaaaacoooon greeeaaaasssssee....
:P
Postby NeFaRiOuS_SLE » Fri Jun 16, 2006 11:54 pm
Good points. What if you notice it tilt a little bit too?
