SolaraGuy.com • View topic - driving axle clicking
Postby scLara626 » Tue Jul 04, 2006 7:48 pm
well im getting noise, some clicking from my driver side axle when i turn. I didnt hit any bumps or any thing so did this come from having the car lowered. And can the warrenty by any chance fix this?
scLara626
Postby Biggi_e » Tue Jul 04, 2006 8:51 pm
i have that too but im not lowered...it happens randomly
Postby MrMikeL » Wed Jul 05, 2006 7:44 am
Is there an outside chance that you have a stone in a tire which is making the clicking sound??
MrMikeL
Postby shocar4 » Wed Jul 05, 2006 8:10 am
cv joint???
shocar4
Postby michaels artic frost » Wed Jul 05, 2006 9:38 am
shocar4 wrote:cv joint???
Perhaps so, my old mx-3 had this problem badly due to bigger wheels. Although I'm not experiencing any issues with my solara (knock on wood)
scLara626...you may want to have it looked at.
-M 8)
Updated 06/01/12: Michael T's
Postby krawzyazn » Wed Jul 05, 2006 10:00 am
did you recently lower your car?
It might be your Strut bearings
Postby kgzero1 » Wed Jul 05, 2006 10:13 am
^^Would they have to be replaced, if this is the case?
I lowered mine about three months ago, and now I get the noise mentioned here. I just turn my steering wheel (while moving or not), and I hear it coming from the where the struts are.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
http://www.cardomain.com/ride/850364
http://www.cardomain.com/ride/2055035
kgzero1
Postby lazyboyz69 » Wed Jul 05, 2006 10:26 am
i thinks its the cv joints or cv boots them if there is any cracks or leaks. If your pass 100k then most likely cv boots.....
lazyboyz69
Postby DatSRBoi » Wed Jul 05, 2006 10:59 am
Coulld be a loose FSB bolt. Thats what happen to mine.
Postby krawzyazn » Wed Jul 05, 2006 10:59 am
kgzero1 wrote:^^Would they have to be replaced, if this is the case?
so it pops when you move the wheel right..... That means the shop that did your lowering jub Crushed your bearings I had that on my car replaced the bearing no more pop
Postby kgzero1 » Wed Jul 05, 2006 2:11 pm
^^Damn it! They did the same crap to my rear ones, cost me a crap load of money!
Now I have to shell out some more!
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
kgzero1
Postby scLara626 » Wed Jul 05, 2006 6:42 pm
am not sure what it is? but i had a similar problem with my accord back in the day, i ran into a huge dip speeding. I got it fixed, but the solara isnt leaking stuff from the axle like my accord. So im not sure it is the axle? what are the symtoms? for the axle or cv boot or any other thing that might be the problem?
" I heard (YOUR NAME GOES HERE) got fired from the sperm bank for drinking on the job''
scLara626
Postby scLara626 » Wed Jul 05, 2006 6:46 pm
oh and my car wasnt recently lowered or anything. Been drooped for close to 3 yrs now. nad i was in a huge accident and got a whole new suspension a 1 1/2 ago. So i think if anything was messed up during the installation of my springs i notice it. But i do rememeber a thread here a while ago about a noise coming from a front spring after ur car gets dropped with trd springs, and i had hat but it seems to have went away
scLara626
Postby scLara626 » Mon Sep 11, 2006 6:00 pm
well ur warranty does cover driving axles, took it in today. There gonna replace my sunroof, regulators on my D/P windows. My axles seemed ok , they said its coming from the spring, and i do have trd springs , but it never ever sounded like that. It sounds just like an axle?
scLara626
