SolaraGuy.com • View topic - transmission oil
transmission oil
transmission oil
Postby xodessitx » Tue Aug 15, 2006 6:31 am
how often do you change your transmission oil?
2004 solara
se sport v6
lunar mist
getting tints probably 20% all around
more coming soon.....
xodessitx
Postby MrMikeL » Tue Aug 15, 2006 6:37 am
Haven't yet with 32k miles.
MrMikeL
Postby MikeATL » Tue Aug 15, 2006 8:09 am
got my 30k checkup the other day. They said the tranny fluid was pretty dark, so i had it replaced.
MikeATL
Postby Jai_Jai_Binks » Tue Aug 15, 2006 10:02 am
FYI: its transmission fluid, not oil. Secondly, how do you guys let it go that dark. Almost every other gas-fill up, i pop my hood and check the fluid levels and i check the color of my tranny fluid. I flush (not to be confused with drain and fill) my tranny fuilds every 30K miles or annually.
Postby Sleeper » Tue Aug 15, 2006 10:26 am
whats the difference between the flush and drain and fill? Does a flush use certain additives?
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Postby mik00725 » Tue Aug 15, 2006 5:35 pm
The difference is that when you drain "all" u'r fluid maybe some will keep on the inners of the tranny. When you flush is like a dialisis it is drained, then additional fluids with some type of detergent and additive are added to fully clean the tranny, then new clean fluid is added until it full. This way u'r sure all your tranny fluid is new and clean (if done the right way)
2004 Arctic Frost Pearl with Dark Stone Leather seats SE.
mik00725
Postby FLUXEMAG » Wed Aug 16, 2006 2:26 pm
I got mine done for free when the gasket blew on the ATF pan three times this year :)
1967 Karmann Ghia Coupe, Rusty White
2005 Solara SE Sport V6, Lunar Mist
2010 G37 Coupe, Moonlight White
FLUXEMAG
Owner's Manual
Postby dchev » Wed Aug 16, 2006 8:11 pm
Hey Guys,
Owner's Manual says that you do not have to change transmission fluid if car operates under normal conditions.
What do you think about that? :o
dchev
Re: Owner's Manual
Postby onefiend » Wed Aug 16, 2006 9:09 pm
dchev wrote:Hey Guys,
If you drive like a senior citizen you fall under this condition.
2007 Camry SE V6
onefiend
Postby onefiend » Wed Aug 16, 2006 9:11 pm
I usually do a drain at 15K miles and then a flush at 30K.
2007 Camry SE V6
onefiend
Postby 4Runner4Christ » Wed Aug 23, 2006 8:58 pm
If you do a pump inlet flush how many quarts of ATF will it take to flush the system & fill it?
My rig: Black 99 4Runner SR5 4WD. Wifes new car: Black 04 Solara SE Convertible.
Got Eternity?
4Runner4Christ
Postby 4Runner4Christ » Wed Oct 18, 2006 9:54 am
4Runner4Christ wrote:If you do a pump inlet flush how many quarts of ATF will it take to flush the system & fill it?
::BUMP:: any one know the answer? Thanks
Got Eternity?
4Runner4Christ
Postby MrMikeL » Wed Dec 06, 2006 12:32 pm
Sorry to revive an older thread. I just had my car in for the 36k service at my shop (not the stealership). At my last oil change, they said that my tranny fluid was discolored. They said they see that frequently with Toyotas. I asked for their recommendation and they said to drain & fill at the 36k service. I asked about a full flush. The labor and parts to do it properly will be over $200, so we decided on a treatment plan, like when you go to the doctor. Once a year I will have a drain service performed. This gets about 4 quarts out and replaces it with 4 fresh quarts and necessary additives. I can do this about 4 or 5 times for the cost of one single flush service. I have trusted these guys for years and they do a great job, so this made sense to me.
MrMikeL
Postby bassthrive » Wed Dec 06, 2006 1:09 pm
Something doesn't sit right with these flush services the shops charge so much for. Chances are, all the nasty gunk and filings from the car before you will then be run through your tranmission. (reason many people get flushes is because their trans is on it's last legs) I am not sure how careful the shops are at preventing this contamination of the flushing equipment.
I stick to a drain and fill every 30k with synthetic, plus I can do this in my garage (I dont trust other people with my car). Maybe i will even invest in an ATF cooler.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby crispone » Wed Dec 06, 2006 1:59 pm
Okay.... here's "my version" of the "skinny" on the x-mission "flush"....
DON'T just DRAIN and FILL.... you are simply diluting the efficacy of the service... may as well not do it at all....
FULL FLUSH and FILL.... (the DIALYSIS method...)
Takes about 10 quarts. (liters)
Buy the proper TOYOTA SPECIFIED fluid yourself.... (talk to the shop you will use up front, and make the "arrangements" before you buy your own fluid, etc...)
They will connect an ATF FLUSH machine (dialysis machine... HA) to your tranny fluid circuit, and drain then RUN THROUGH several quarts to "RINSE" the old fluid and residual contaminants out of the valve body, clutch packs, coolant jackets, etc.... then when they have thoroughly flushed the system to "clear".... they'll disconnect the machine and make sure it is "topped off" to the proper level.
I paid the regular 4-5 bucks per quart for the fluid at Toyota, then had the job done RIGHT at my local oil change shop... and it cost me a little over $50 for the full flush. I did my change at about 32k HIGHWAY miles.... on a (THEN) stock '04 V6 Solara.... (I'll do it at 20-25k now that I am driving ALOT harder w/CP-e and other mods...)
RESULTS:
FANTASTIC! MUCH better shift action, quicker shifts, smoother shifts, firmer shifts, better shift response.
NOTE: MANY shops/manuals will tell you that you SHOULDN'T change tranny fluid unless you have performance deterioration, or BURNT fluid, etc.... (the: "If it ain't broken, don't fix it..." philosophy...) There are REASONS for this... namely, the way the clutch packs get "empregnated" with the tranny fluid and everything "seats in"... wherein sometimes, you can CHANGE the fluid and experience DETERIORATION of tranny performance... Personally, I don't know if this was more of an issue with OLDER cars and fiber clutch packs and fluids, etc... but my personal experience has been to CHANGE it at an interval suited for your driving, and to do so with a proper (THOROUGH) flush.
CAUTION: I would be VERY CAREFUL about having ANY kind of detergent or "cleaner" agent run through my tranny.... BEST to stick with the SAME SPECIFIED FLUID you will run in the tranny when it's full. Otherwise, you are just risking further contamination from either:
a) The "dis-similar" fluid that is left residually in the tranny.... or....
b) The "contaminants" that would otherwise NOT have been "introduced" (broken loose) into the fluid with a straight tranny fluid flush... (This is ESPECIALLY true with OLDER vehicles, that haven't had their service done REGULARLY.... If done REGULARLY, and in the manner described above.... I think you will enjoy a trouble-free tranny experience.... barring abuse, of course....)
Just my thoughts.... any comments? (I'm no expert here.... I just stayed at the HOLIDAY INN EXPRESS again....)
