SolaraGuy.com • View topic - The MAINT light flashes when I turn the car on...?
Postby RDKamikaze » Thu Aug 17, 2006 3:13 pm
Ok, so I got in my the other day and noticed when I turned it on that the MAINT light flashed after the usual startup, but didn't stop. It kept going for about 5-7 flashes I didn't count, what should I do? Is there a flash code for X amount of flashes = what or do I just pop the hood and see what I can do? Thanks for the info!
RDKamikaze
Postby linmk2 » Thu Aug 17, 2006 4:12 pm
The MAINT light starts to flash when it's near time to change the oil. When you start the and stays on, that means the oil needs to be changed NOW. Once the oil has been changed, the light needs to be reset. I will have to refer to my owners manual for that one. But if you have yours, look for the instructions to re-set the lamp.
Howard
linmk2
Postby kingkakyle » Thu Aug 17, 2006 4:55 pm
yep
its a friendly reminder that comes up when its almost time for an oil change
it turns on and stays on every 5k miles
Postby RDKamikaze » Thu Aug 17, 2006 5:58 pm
Ok thanks for the info, I found out about it after I called the local Toyota about 2 minutes after I posted lol, mybad! Next time I'll reffer to them first, and please post the reset instuctions b/c I don't have my manual.
RDKamikaze
Postby tacti » Thu Aug 17, 2006 6:40 pm
to reset the maint light,
make sure that your odometer shows actual odometer, not trip meter.
take the key out if it's in the ignition.
put the key, and press and hold odometer button.
while you are holding, turn the key to on position.
you will see odometer changes to "------"
and start reducing the number of line.
once you see all 0 on your odometer, your maint light is reset.
let me know if you have any trouble.
Tact
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby PXLpainter » Thu Aug 17, 2006 6:55 pm
linmk2 wrote:The MAINT light starts to flash when it's near time to change the oil. When you start the and stays on, that means the oil needs to be changed NOW. Once the oil has been changed, the light needs to be reset. I will have to refer to my owners manual for that one. But if you have yours, look for the instructions to re-set the lamp.
That is, unless you're running Mobil 1 ;)
Postby MrMikeL » Fri Aug 18, 2006 7:45 am
Have you thought of reading your owner's manual first??
MrMikeL
Postby PhreakdOut » Fri Aug 18, 2006 8:12 am
MrMikeL wrote:Have you thought of reading your owner's manual first??
LOL - It happens to all of us. :wink: The owners manual does read like stereo installation instructions filled with silly precautions.
Postby Down2TheC » Fri Aug 18, 2006 9:58 am
^^^ and the index kinda blows.
Down2TheC
Postby swindler » Fri Aug 18, 2006 10:45 am
RDKamikaze wrote:...and please post the reset instuctions b/c I don't have my manual.
^^^ and he said he didn't have his manual.
2006 SLE V6 Convertible
swindler
