SolaraGuy.com • View topic - front bumper dismounting
Postby KSolara » Mon Aug 21, 2006 10:33 pm
I will be clearing my corners soon..
i just wanted to know if there is any tricky bolts or clips when dismounting the front bumper..
any other advise will be appreciated too
o4 SE I4 Lunar mist
KSolara
Postby tacti » Tue Aug 22, 2006 4:12 am
i did before, and it was not hard at all.
probably easier if you have someone to help you tho.
each person can work on each side, and you just need to pull straight out.
there are several bolts on top, and also you need to take under body cover (that black plastic thing under engine), and wheel well cover thing.
(might be another bolts behind the wheel well...)
then just pull out straight toward front, and you got it out.
good luck on your project!
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby KSolara » Wed Aug 23, 2006 3:38 pm
project complete
thx tacti
btw.. i baked the headlites instead of using the dryer
it came out pretty nice
o4 SE I4 Lunar mist
KSolara
