SolaraGuy.com • View topic - Help? How do I remove the rear panel
Postby LaZy8aStArD » Sun Sep 03, 2006 3:36 pm
Hi guys, yes i know do a search, I did a search and nothing came up. For those of you who have removed the rear panel to change your rear speakers how did you do it? I have been staring at the thing for almost 2 hours now and still cant figure it out, i took out other panels to try an get to it and still nothing. if you can provide a picture that would also but nice, but any word of advice can help. I am trying to place dynamat on the rear deck as well as change the rear speakers. thanks again
2005 Solara SLE V6
LaZy8aStArD
Postby SolaraPete » Sun Sep 03, 2006 4:00 pm
1. Remove the rear seat bottom
2. Remove 2 screws in the "oh S*!t" handle on the side piece
3. Remove the seatbelt bolt
4. Remove the coat hanger holder
5. Unclip the door sill piece on the edge that connects with the lower
side panel
6. Remove one phillips screw on the bottom of the panel
7. Pull the lower portion of the side panel toward you - it's held on by
plastic fasteners (this panel will not come all the way out of the car as
its attached to the folding hinge of the rear seatback - i never felt like
taking that out and its not necessary)
8. Remove the upper portion of the panel - its held on by metal & plastic
fasteners
9. Repeat 1-8 for the opposite side
10. Remove the rear shelf
SolaraPete
Postby LaZy8aStArD » Sun Sep 03, 2006 4:20 pm
Thanks :D, I can see everything else, but how do I remove the rear bottom seats, i keep pulling and tugging and it won't pop out.
2005 Solara SLE V6
LaZy8aStArD
Postby SolaraPete » Mon Sep 04, 2006 9:03 am
There's 2 clips on the front of the seat cushoin (if you were sitting in the back it would be right between your knees) one on each side. Just pull up and it will pop out.
Hmm just noticed your signature - you might want to disregard this as these are the instructions for a Gen 1 rear speaker removal - sorry
SolaraPete
Postby LaZy8aStArD » Mon Sep 04, 2006 9:15 am
No worries, they were pretty similar, I probably didnt need to take out the coat hanger other than that it was right on. Yea I finally got the seat off after a really hard pull. thanks again
2005 Solara SLE V6
LaZy8aStArD
