SolaraGuy.com • View topic - rear defroster
rear defroster
rear defroster
Postby xodessitx » Thu Sep 07, 2006 4:50 pm
i turn the rear defroster and the light light up on the button, but the window is not clearing up. what should i do?
2004 solara
se sport v6
lunar mist
getting tints probably 20% all around
more coming soon.....
xodessitx
Postby theprodigy79 » Thu Sep 07, 2006 7:13 pm
That's kinda odd... I'd check your fuses, then go to the dealer if it continues to be an issue.
theprodigy79
Postby MCOjerry » Thu Sep 07, 2006 7:27 pm
Mine doesn't work either...I'm convinced it because the top rubs on the coils when it goes down.
Postby theprodigy79 » Thu Sep 07, 2006 7:37 pm
MCOjerry wrote:Mine doesn't work either...I'm convinced it because the top rubs on the coils when it goes down.
Your situation is more understandable, however he has a SE Sport... No top to rub :-P
theprodigy79
Postby MCOjerry » Thu Sep 07, 2006 8:15 pm
Oh, I know...I was just commiserating :D
One of these days I'll take it in to Toyota and complain. I'm sure it's the top.
Postby MrMikeL » Fri Sep 08, 2006 9:11 am
Depends on what you're trying to clear. Frost should melt quickly. Fog inside the window should clear eventually. Fog outside the window may not clear quickly at all. Remember, this feature is for clearing temperature induced fog, or frost. A heavy morning dew was not meant to be cleared with the rear defogger.
MrMikeL
Postby Mayor » Fri Sep 08, 2006 1:03 pm
I have the same problem with my "04 SLE Convt. The problem is that I DID take it to Toyota (under warranty) and they gave it back to me and said it WAS working.
Since it really has been nice weather here in PA/NJ (home/work) I havent really had a chance to really test it.
Actually, I dont know how the hell I should test it other than shaving some ice cubes over my back window and seeing if they melt with lines through it... :drinking:
Thanks,
Mayor
Mayor
Postby gone » Fri Sep 08, 2006 1:32 pm
do you have tints on ur car? I had a problem with my other car and it was the tint, the guy messed up or something
gone
Postby xodessitx » Sat Sep 09, 2006 7:59 am
i had tints for over a year and it was working fine. the car was parked for 2 weeks since i was on vecation, when i came back it was raining and the window was foggy so i turned the switch on and it is not working, even though the light in the switch turns on. if the fuse was blown out would the light turn on on the switch?
2004 solara
se sport v6
lunar mist
xodessitx
Postby MCOjerry » Sat Sep 09, 2006 8:52 am
The coils are easy to damage. They can be broken by washing your window.
Only a few coils on my car work. Like I said, I'm convinced it's due to the top rubbing on the coils and damaging them.
Postby xodessitx » Sat Sep 16, 2006 11:22 am
where is the fuse for the read defrster, and what number is it?
2004 solara
se sport v6
lunar mist
xodessitx
Postby TCNO SOL » Fri Jul 04, 2008 10:09 pm
I know this is an old thread, but my 2007 Solara Convertible's rear defroster isn't working. The light turns on when I press the button and the side mirrors do heat up and clear. I checked the rear glass and it DOESN'T get warm at all.
I checked the fuse and it's totally fine. Is there anything else I should try before I hit up the dealer?
Dan
TCNO SOL
Postby TCNO SOL » Tue Jul 22, 2008 5:52 pm
I ended up getting it repaired under warranty by the dealer. They had to order a completely new top, and they sublet it out to a local professional convertible top installer.
I have a new top, the rear defroster is working now, and the whole process only took two full business days.
I also ran my Solara through the automatic car wash, and no leaks! :)
Dan
TCNO SOL
Postby JoBu » Wed Jul 23, 2008 4:14 am
On a similar but different take, my rear defroster ('04 SE Coupe) causes static through my speakers when I have the radio on. I haven't checked to see if it interferes with the CD player. I'm scratching my head on this one. I'd have to believe I don't have a solid ground somewhere.
Cheers,
Joe
I hope that when I die, people will say of me, "Gee, that guy sure owed me a lot of money"... J. Handy
'04 Solara SE Coupe (I-4, 5M)
JoBu
Postby Gadgetjq » Wed Jul 23, 2008 6:50 am
TCNO SOL wrote:my 2007 Solara Convertible's rear defroster isn't working. The light turns on when I press the button and the side mirrors do heat up and clear. I checked the rear glass and it DOESN'T get warm at all. I checked the fuse and it's totally fine. Is there anything else I should try before I hit up the dealer?
If you have a multimeter check for 12V at the window connectors. If you have power, switch to 'continuity' and make sure there's a good path through all the tracings. If there's no continuity one of the tracings may have gotten scratched and broken (it doesn't take much). You can buy rear window defroster repair tape. You just have to locate the break if there is one.
Cheers
Gadgetjq
