SolaraGuy.com • View topic - The size of lug nuts for the Gen 2 wheels?
Postby stockae92 » Sun Sep 10, 2006 9:47 pm
whats the size of lug nuts for the Gen 2 wheels?
2006 Solara SLE V6
stockae92
Postby PXLpainter » Sun Sep 10, 2006 9:52 pm
Do you mean what size socket to use - or thread size?
Postby DatSRBoi » Sun Sep 10, 2006 9:56 pm
i used 12mmx1.5 conical seat
Postby stockae92 » Sun Sep 10, 2006 10:02 pm
it uses 12mm socket then?
cool, thanks for the info :)
2006 Solara SLE V6
stockae92
Postby siennasc98 » Sun Sep 10, 2006 10:18 pm
stockae92 wrote:it uses 12mm socket then?
12mm is the size of the bolt (wheel stud), 1.5mm is the thread pitch.
You might need a 19 mm or 21mm socket for the lug nuts.
siennasc98
Postby stockae92 » Sun Sep 10, 2006 10:22 pm
oh oh
seems like i got the term confused :p
thanks for the clarification
now i need to find out if i need a 19mm or 21mm socket (basically to take off the wheels)
2006 Solara SLE V6
stockae92
Postby cklinh » Mon Sep 11, 2006 8:35 am
er... there should be a lug wrench (proper term?) in your trunk... where the spare is...
cklinh
Postby stockae92 » Mon Sep 11, 2006 10:24 am
i am looking for a socket for the torque wrench
i've read the manual and it only tells me i said torque it to 77 lb, but doesn't mention anything about what size of the socket should i use
2006 Solara SLE V6
stockae92
Postby stockae92 » Tue Sep 12, 2006 10:18 am
i found one its 21mm, just in case anybody else wants to know :)
2006 Solara SLE V6
stockae92
