SolaraGuy.com • View topic - Brake squeal?
Brake squeal?
Brake squeal?
Postby SolaraChihuahua » Mon Sep 25, 2006 2:32 pm
Anyone know if I can stop my brakes from squeeling under light braking pressure? Its not horrible but t is definitely noticeable. Still has the original brake pads that it came from the dealer installed..
2005 White SE V6--
Ground Effects
Window Tint (street legal for AZ)
Satellite Radio
IPod Player
Pictures- http://www.solaraguy.org/viewtopic.php? ... sc&start=0
SolaraChihuahua
Postby cklinh » Mon Sep 25, 2006 2:48 pm
How many miles? You sure they don't need replacing?
cklinh
Postby SolaraChihuahua » Mon Sep 25, 2006 3:23 pm
a little more than 14,000 miles...so I dont think so
2005 White SE V6--
Ground Effects
Satellite Radio
IPod Player
SolaraChihuahua
Postby FLUXEMAG » Mon Sep 25, 2006 3:49 pm
I had the same problem, my older friends couldn't even hear what I was talking about. But it was pretty annoying with the windows down and the stereo off.
So I took all 4 sets of brakes off, inside and outside pads, used a metal brush to clean them. Sprayed them with an air compressor hose. No luck, still squeel.
This time I was more serious. So I did the same as before, but then I put some blue RSV gasket maker in between the pad and the shim for all pads. This made it better, but still I can hear it.
Screw it, I bought a new stereo system and I never hear it anymore. BTW the pads had >60% left on them, probably 80% when they first started acting up.
1967 Karmann Ghia Coupe, Rusty White
2005 Solara SE Sport V6, Lunar Mist
2010 G37 Coupe, Moonlight White
FLUXEMAG
Postby MikeATL » Tue Sep 26, 2006 1:22 pm
Same problem here. I have 32,000 but I have a good 5-10k miles left on them.
Anyone have any experience with ceramics? How are they with brake dust and noise?
MikeATL
