SolaraGuy.com • View topic - A question regarding caliper painting
Postby Jack Soulfire » Thu Oct 05, 2006 7:20 pm
I know caliper painting has been discussed already, but I have a question that I believe hasn't really been discussed in detail and I want to make sure I do this correctly.
I bought jack stands and necessary equipment and materials, but I'm wondering if I need to remove the calipers when painting, or can I just tape over what needs to be taped and paint with the calipers attached?
Excuse my ignorance on the subject, I've just never painted a set before, and I don't know much about the calipers and how they are removed and reattached. I don't want to do anything stupid when I do it this weekend. If I should remove them, is this difficult? Also, if it's easy to describe would anyone mind explaining how.
Any help is greatly appreciated.
Thanks,
Jack
2006 V6 Solara SE Sport
Jack Soulfire
Postby PXLpainter » Thu Oct 05, 2006 9:26 pm
If you're lazy like me you just get a couple beers, jack 'er up and tape off everything you don't want painted! :D
Postby sahuddleston » Thu Oct 05, 2006 9:29 pm
no need to remove them, i painted mine in the parking lot at school and they look great....
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby iinokturnolii » Thu Oct 05, 2006 9:33 pm
jack,
i got mine caliper paint kit from walmart. and it had everything i need the paint, tape, caliper cleaner and a paint brush. remove the wheels, tape off the part you dont want to get paint on... and then just paint away with the brush. the kit i think is about $15.00 bucks or so. took me about 1 1/2 hour. cause i only had 2 jack stands. its pretty easy... 8)
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Postby woa_its_j3ff » Thu Oct 05, 2006 9:34 pm
^ I think a lot of ppl have done that thing with the taping off. now in relation (sort of to his question) what kind of paint should I use?? because i want to do the same thing for my car..
Postby sahuddleston » Thu Oct 05, 2006 9:36 pm
an acrylic based paint, same thats used for engine enamel paint... or anything for high heat use.
sahuddleston
Postby iinokturnolii » Thu Oct 05, 2006 9:38 pm
woa_its_j3ff wrote:^ I think a lot of ppl have done that thing with the taping off. now in relation (sort of to his question) what kind of paint should I use?? because i want to do the same thing for my car..
caliper paint kit from walmart...
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Postby cklinh » Thu Oct 05, 2006 9:44 pm
I just grabbed "engine enamel" from an autoparts store... (more color varieties, even though I got black :)... as well as a can of Brakleen... about ten bucks altogether (and reusable...)
cklinh
Postby PhreakdOut » Thu Oct 05, 2006 9:51 pm
I pulled the calipers off the rotor but I didn't disconnect them from the brake lines. There are two bolts on the back side. Remove them and slide the caliper off the rotor. VERY easy.
Use a coat hanger and bend it up so you can hang the caliper.
I used a plastic grocery bag over the entire rotor assembly and rags over other critical areas.
I wish I had spent more time cleaning the caliper. (I had spots that the paint wouldn't stick to.) Try a fine wire wheel attached to a dremmel or drill.
Best of luck. Post up the final outcome!
Postby PXLpainter » Thu Oct 05, 2006 11:18 pm
I used Bestine to clean the parts while still attached to remove any dirt and oils - dries as fast as acetone but won't hurt any rubber parts. Even taking the calipers off the discs you'll have plenty of tape masking to do. ;)
I bought 1 can of Caliper Paint from Auto Zone (spray can - NOT a brush!) :o
Several really dry-misted coats first then a couple slower glossy coats. Still looks like new. :D
Postby Jack Soulfire » Fri Oct 06, 2006 1:22 pm
PhreakdOut wrote:I pulled the calipers off the rotor but I didn't disconnect them from the brake lines. There are two bolts on the back side. Remove them and slide the caliper off the rotor. VERY easy.
Thanks for the info on removing the calipers. I may try that route if I can find the bolts easily and have the proper size attachment for my socket wrench.
Also, a side note, I already purchased my paint (duracolor caliper kit) a long time ago, but thanks anyways for offering advice on paint.
I'll post pics and let you know how it went down after this weekend.
Jack Soulfire
Postby steve-o » Fri Oct 06, 2006 5:32 pm
Yeah, walmart stocks a lot of good stuff. TI see the started stocking K&N. they sell the duracolor kit. Not many color options though.
steve-o
Postby RDKamikaze » Tue Oct 10, 2006 11:51 am
I got my duracolor kit at Autozone, same price as Wal-Mart and same thing. I just removed the wheels and painted each layer on each caliper. Just rotate around the car and it's so efficient because the other 3 calipers dry while you paint that one and so on. No need to remove, just jack, remove wheel, tape and paint!
P.S. I suggest safety glasses and crappy clothes because my new shoes got some red spots on them from the paint lol! Also, my safety glasses prevented some accidentalt splashes of paint from going into my eyes, thank goodnes I was wearing them!
RDKamikaze
Postby MikeATL » Tue Oct 10, 2006 12:13 pm
pics please.
MikeATL
Postby PXLpainter » Tue Oct 10, 2006 2:33 pm
RDKamikaze wrote:P.S. I suggest safety glasses and crappy clothes because my new shoes got some red spots on them from the paint lol! Also, my safety glasses prevented some accidentalt splashes of paint from going into my eyes, thank goodnes I was wearing them!
LOL! :lol: Hey - we're not all as messy as you are! :D
But yeah, I got some :pink: overspray on my shoes and garage floor, so old shoes and pants are pretty good idea. Goes without saying when you're painting anything anyway! ;)
