SolaraGuy.com • View topic - run flat tires?
run flat tires?
run flat tires?
Postby mluu510 » Thu Oct 19, 2006 11:28 pm
our cars have tire pressure monitor. does that mean i can upgrade to run flat tires? they're so cool and i wanna get rid of the spare in my trunk. put a nice sub or something =D
mluu510
Postby Turbosolara » Thu Oct 19, 2006 11:40 pm
run flat is extremely expensive, not worh it. And run flat just means you can run flat at 50mph until you found a tire shop to help you replace another tire. it still require replacement after you got nails.
my friend's 1 years old bmw 330i already replaced 3 run flat tires, about $400 each
Postby mluu510 » Thu Oct 19, 2006 11:45 pm
ouch! a lot of new luxury cars are using run flat tires as standard. i was hoping only cost a little more than regular tires.
i don't mind driving slowly when it's punctured. i just don't wanna pull over and replace my tires. it feels so ancient, lol.
mluu510
Postby NeFaRiOuS_SLE » Fri Oct 20, 2006 12:21 am
Another thing to keep in mind is that most run flat tires use a solid core, which means that the day-to-day ride quality with them are more stiffer and more interior road noise. Luxury cars know how to compensate for this with better noise dampening and the shocks are tuned differently and is that way from the factory.
Besides, don't you just love pulling over, changing it and drive with the car forcing itself to turn to the side? [/sarcasm]
Postby Turbosolara » Fri Oct 20, 2006 12:23 am
that's why you need AAA membership if you are lazy
Postby steve-o » Fri Oct 20, 2006 8:32 am
The tire guys need a special machine for run flats due to the rigidity. The average "down the street mechanic" can't fix 'em cause they don't want to spend the money for machines that support them..
steve-o
Postby mluu510 » Fri Oct 20, 2006 11:19 am
Turbosolara wrote:that's why you need AAA membership if you are lazy
hehe good point. but, doesn't AAA only willing to toll your car for a short certain miles (most likely 5miles) before they start charging you?
mluu510
Postby kingkakyle » Fri Oct 20, 2006 11:29 am
yea they charge u after a certain amount of miles.....iim not sure how many
but maybe 5-10 miles?
u can also call them to change ur tire for u ^ ^ thats free....except i tip them
