SolaraGuy.com • View topic - rear defroste?
rear defroste?
rear defroste?
Postby xodessitx » Sun Nov 12, 2006 7:49 am
i have a problem with the rear defroster, the wires that are attached to the window under the panel just came off from the window? does anyone know how to attch the 2 metal pieces back to the window so they can stay, is there like special glue to use?
2004 solara
se sport v6
lunar mist
getting tints probably 20% all around
more coming soon.....
xodessitx
Postby NeFaRiOuS_SLE » Mon Nov 13, 2006 10:17 am
You might need to clarify it with pictures. If it's at the ends where it supplies the power, that might be a different story, but if it's the thin wires that run the length of the window themselves, you might want to try a repair kit that paints the lines on.
Postby xodessitx » Tue Nov 14, 2006 9:24 pm
it is the connectors on the window, not the lines that run through. what can i use to attach it back to the window?
2004 solara
se sport v6
lunar mist
xodessitx
Postby NeFaRiOuS_SLE » Sat Nov 18, 2006 8:36 pm
That might be covered under warranty (if it's still in effect); you might want to bring it back to the dealership. That way if some DIY fails, at least it won't be voided that way.
Postby xodessitx » Mon Nov 20, 2006 7:55 am
is there any glue that can be used to attach it back to the window i dont feel like going to my dealer for that i hate going there in general!
2004 solara
se sport v6
lunar mist
xodessitx
