SolaraGuy.com • View topic - any tips for changing the oil
Postby Projex0 » Sat Nov 25, 2006 8:55 pm
hey im about to do my first oil change on the solara, i was wondering to get to the filter do i need to take of the plastic pieces under there to get to the filter?
dont get me wrong i've changed oil b4 but the solara is different somehow freakin engine is big. any tips
Projex0
Re: any tips for changing the oil
Postby crispone » Sat Nov 25, 2006 9:06 pm
Projex0 wrote:hey im about to do my first oil change on the solara, i was wondering to get to the filter do i need to take of the plastic pieces under there to get to the filter?
Don't forget to put the drain plug back.
What kind of rims are those?
Postby Projex0 » Sat Nov 25, 2006 9:12 pm
oh they are bronze enkei rs7 18"
any other tip??
Projex0
Postby crispone » Sat Nov 25, 2006 9:41 pm
Projex0 wrote:oh they are bronze enkei rs7 18"
any other tip??
This is actually the first car I haven't done most of the oil changes on. I do alot of highway/work related driving, run a busy schedule, and have a fantastic oil change place that does it with 100% synthetic....
off the topic...
Anyway, I have noticed that the filter (V6 SE Sport '04) is RIGHT THERE in these new Toys... all you have to do is reach down from the front... right behind the radiator. I think you can do it without removing anything... but I believe I found the drain plug/access under the front to be a tight crawl... I don't think there is anything special about these, other than the usual oil-change "do's and don't" to mind...
-crisp :evilbat: (lotta help THAT was... 8) )
Any shots of the rims from the side view?
Postby Projex0 » Sat Nov 25, 2006 11:11 pm
yeah i know that i can probably reach down to get at the filter but i dont want to burn my arm in the process since the headers in right next to it, thats y i was wondering if going from the bottom would be best or not cause i would have hate to take those under panels off just for a 30 min oil change ya know.
side view of the rims
http://www.solaraguy.org/viewtopic.php?t=27928
Projex0
Postby crispone » Tue Nov 28, 2006 10:16 am
Projex0 wrote:yeah i know that i can probably reach down to get at the filter but i dont want to burn my arm in the process since the headers in right next to it, thats y i was wondering if going from the bottom would be best or not cause i would have hate to take those under panels off just for a 30 min oil change ya know.
I'd still recommend reaching down. Just give it a 20 minute header cool-off time. The oil will still be plenty hot to drain well... and you won't burn your arm...
Let us know what you try and think afterward...
