SolaraGuy.com • View topic - Programming extra (added)key for 2006
Postby upssnowman » Sat Dec 30, 2006 11:36 am
I have a 2006 SLe and have tried every program method for the 2006 and cannot get any to work I think all the diferent methods on the net are for older models , does anyone know for sure the method to add an extra key for the 2006 I have the new key I bought from Toyota and had it cut but need to add it as extra, if you can help I'd appreciate it , I did add some (2) extra remotes but cqan't program key thanks much, Happy New Year,,,snowman
upssnowman
Postby Down2TheC » Sat Jan 06, 2007 9:33 am
This is not a tutorial so I'm moving it to Gen2
Down2TheC
Postby whdean » Sat Jan 06, 2007 9:56 am
Assume it's the same as with a 2005 SLE, which I have. Starting in 2004, SLE keys must be programmed thru the onboard computer. You will need a real Toyota transponder key, which you appear to have. Either take it back to the dealership, or to a locksmith that has a computer interface. I added keys to mine thru a locksmith. He needed an original key (not valet) and hooked up a handheld computer device to a connection under the dash. I think I paid $90 for two keys and two programmings. The dealership wanted $40 per key and $85 per key to program.
Hope this helps.
whdean
Postby RDKamikaze » Wed Jan 10, 2007 3:36 pm
I created a pretty handy tut for this. A link can be found HERE
EDIT: Nevermind, readin through your post a little closer (I must be dumb for missing it) revealed that you want it for the KEY, not the REMOTE. Lol, sorry about that!
RDKamikaze
Postby upssnowman » Wed Jan 10, 2007 3:50 pm
This says it to program the remotes , I need to program the Key to the security system there is a way it can be done with a sequence withpout the dealer and their expensive machine
upssnowman
Postby PXLpainter » Wed Jan 10, 2007 3:52 pm
upssnowman wrote:This says it to program the remotes , I need to program the Key to the security system there is a way it can be done with a sequence withpout the dealer and their expensive machine
Hmmm... rotsa ruck with that one! :roll:
