SolaraGuy.com • View topic - Belt noise
Belt noise
Belt noise
Postby lambition » Sat Jan 06, 2007 9:55 am
My 2004 solara began making squeaking noise early last year, but it went away after the engine warmed up. However, not its making that noise all the time.
Same thing with my mother's 2004 Highlander.
Anyone else experiencing belt squeaking noise ?
Do anyone know if this is covered by powertrain warranty?
lambition
Postby SolaraBlue » Sat Jan 06, 2007 10:06 am
does it do this when its cold? can you describe the noise a little better?
im thinking its normal toyota engine noise......
Postby lambition » Sat Jan 06, 2007 10:11 am
It used to do that only when it was cold, but now its making noise all the time.
Its squeaking like some old cars.
I just found a TSB for Accessory drive belt squeal / belt tensioner rattle. I'm guess that is the problem, but I don't know what is warranty term for this (I couldn't get hold of the document itself).
SolaraBlue wrote:does it do this when its cold? can you describe the noise a little better?
lambition
Noice recording
Postby lambition » Sat Jan 06, 2007 10:52 am
I just recorded the noise.
http://mason.gmu.edu/~boh1/V0106000.MP3
This is after the engine warms up for a while. Its worse when it is cold.
lambition
Postby unbalancedwood » Sat Jan 06, 2007 12:11 pm
labition, i have a sound like that, it might just be a pully loose, i was gonna look at it today more.
ps, whats your car look like? ive seen a few solaras i havent seen before around the nova area
unbalancedwood
Postby Ruski » Sat Jan 06, 2007 12:17 pm
i have the the same problem with my 00 and i also recorded it today to see what it can be but mine is much louder off a squeal. what ius causing this problem i have 80 k on the car
Postby lambition » Sat Jan 06, 2007 12:19 pm
Mine is just regular silver 2004 solara. No mods done outside.
I just put some lightings inside car and thats about all I have done.
lambition
Postby sgunitkc » Sun Jan 07, 2007 3:09 am
Yea, I have the same noise when the car is first started in the morning after it has been sitting out in the cold for a while. Is this really the belt noise? I'll try to see what I can find in the TSB and ask around...let me know if you find anything.
sgunitkc
Postby lambition » Sun Jan 07, 2007 8:54 pm
It could be bearings as well, but I wouldn't know for sure.
I'm guessing its either bearings on pully or tentioner not doing its job causing the belt to slip.
lambition
Postby sgunitkc » Sun Jan 07, 2007 9:38 pm
TundraSolution has bunch of TSBs that apply to our cars...and the belt noise is one of them...here's the link to all of them. If you want the details of each TSB though you need to be a paid subscriber.
http://www.tundrasolutions.com/forums/local_links/links/115[/url]
sgunitkc
Postby lambition » Tue Jan 09, 2007 5:13 pm
Took my car to the dealer today.
I told them to fix the noise problem and upgrade ECM program as well.
After about 5 hours of waiting (at home) I finally got call from the dealer only to hear I cannot get the car back today!
Service ref. told me during upgrade something went wrong and fried ECM. :(
I believe it was not really fried, but just lost contents of the flash rom. Anyway, they will be installing new ECM tmr.
Hopefully everything goes well.
lambition
Postby lambition » Wed Jan 10, 2007 2:39 pm
Just brought the car back.
They did not find noise problem. :roll: I also could not hear any noticible noise.
Hofully its really gone. (which is unlikely. :( )
They have replaced ECM module as well.
They recorded that problem like this.
"FOUND ECM TO BE FAULTY WAS NOT CONTROLING SHIFT PATTERNS AND WILL NOT COMMUNICATE WITH SCAN TOOL
REPLACE ECM TEST DROVE THEN RESCANED COMPUTER ALL GOOD"
I will have to see if shift lag is gone as well. I could not really feel difference while drving back to home cause there were traffic jams.
If the noise becomes really noticible again, I will try to get a good recording and let them hear the noise.
lambition
Postby anttarz » Wed Jan 10, 2007 3:42 pm
from my experience toyota belts tend to squeak when getting worn. I have used STP Belt Stop-Squeal belt dressing in the past to eliminate or minimize belt noise.
anttarz
