SolaraGuy.com • View topic - squealing noise..from rims?
Postby Biggi_e » Wed Jan 17, 2007 12:06 pm
i guess this started recently but when i drive i can hear a squealing noise comming from my left side, when i stop the noise is gone. i dont know what it is. any suggestions? could something be wrong with my rims? the car doesnt feel wobbly or anything.
Postby Solarafreek » Wed Jan 17, 2007 12:08 pm
brakes?
Solarafreek
Postby Biggi_e » Wed Jan 17, 2007 2:07 pm
i dont know if the brakes cause i dont even touch them and it squeals
Postby **PoshPepper** » Wed Jan 17, 2007 2:14 pm
It is most likely the brakes... I had the same thing happen to me about 2 months ago... just replace your front pads (I am assuming it is coming from the front) also, depending on how fvcked up your rotors are you may have to get those resurfaced...
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby anttarz » Wed Jan 17, 2007 2:14 pm
the brake heat shield? see if it is rubbing against the rotor.
to clarify i believe the problem is when moving (NOT BRAKING). So the rotors and pads are probably fine.
anttarz
Postby **PoshPepper** » Wed Jan 17, 2007 2:21 pm
anttarz wrote:the brake heat shield? see if it is rubbing against the rotor.
I know... He said he is having the noise when driving... and not necessarily during braking... but I did have the exact same symptoms (noise during driving-- and actually was less when braking), and it was the pads/rotors in my case...
Milt's OTHER ride
**PoshPepper**
Postby anttarz » Wed Jan 17, 2007 2:46 pm
true it could definitely be a warped rotor or pad. It's just extremely common for the heat shield to get knocked and rub against the rotor. You can check if its the heat shield without even removing the rim, just push it back with a stick through the spokes.
anttarz
Postby FLUXEMAG » Wed Jan 17, 2007 3:08 pm
Brake pads have a dragger that pops out once the pad is worn enough. It's put there so you hear it and replace the brakes.
1967 Karmann Ghia Coupe, Rusty White
2005 Solara SE Sport V6, Lunar Mist
2010 G37 Coupe, Moonlight White
FLUXEMAG
Postby Biggi_e » Wed Jan 17, 2007 3:18 pm
FLUXEMAG wrote:Brake pads have a dragger that pops out once the pad is worn enough. It's put there so you hear it and replace the brakes.
well i realized that when i just bought my rear brake pads but the noise you can hear more on the left side of the car then the right. ill have it fully checked out on friday by my mechanic. my front pads are still good so im not sure yet. thanks for the input guys and girl :D
Postby sgunitkc » Wed Jan 17, 2007 10:13 pm
if it's not your brake pads, it could be your Front Brake Hardware Kit.
sgunitkc
Postby alan8888 » Sun Jan 21, 2007 9:24 pm
oh i got the same sound, but for me, it just start for 2-3 weeks,,, is from rear. left....don't know what;s going on...may be is time to go for the tein suspenion :-)
alan8888
Postby Biggi_e » Sun Jan 21, 2007 9:57 pm
well i found out what it was. it was my left rear brake sensor cause my pads were worn down. well the noise stopped after the sensor broke lol! you dont really need it but i replaced it and my pads. the right side wasnt as worn down for some reason..
Postby Down2TheC » Mon Jan 22, 2007 5:18 am
That'll teach you to doubt the Posh!
Down2TheC
Postby **PoshPepper** » Mon Jan 22, 2007 10:43 am
Down2TheC wrote:That'll teach you to doubt the Posh!
LOL! :drinking:
Milt's OTHER ride
**PoshPepper**
Postby SolarBoy » Mon Jan 22, 2007 11:57 am
Biggi_e wrote: the right side wasnt as worn down for some reason..
Hopefully the left side piston isn't in need of repair...I'm sure your repair guy took care of it :o
SolarBoy
