SolaraGuy.com • View topic - Sqeaky noise
Sqeaky noise
Sqeaky noise
Postby dishon22 » Wed Feb 28, 2007 3:02 pm
im in ny and it gets very cold out here the past 2 weeks im hearing this sqeaky noise when i after i start the car in the morning it tones down after 10 minutes has any had this problem or might know what it it 2004 sle with 54k miles
dishon22
Postby ClassySolaraGuy » Wed Feb 28, 2007 3:04 pm
Belt tensioner or belt?
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby Down2TheC » Wed Feb 28, 2007 3:05 pm
It's a very cold fanbelt. Well... it could be. Next time you start it up and hear that, give the gas a bump and see if it gets faster. If it does, it's a fanbelt and not a big problem. (you could spray some belt dressing or just wait for spring)
Down2TheC
Postby anttarz » Wed Feb 28, 2007 3:08 pm
belt dressing works pretty well, but inspect the belt, it may need to be replaced. I suspect your belt is still good for quite a few more miles, toyota belts tend to make a some noise when cold.
anttarz
Postby dishon22 » Fri Mar 02, 2007 2:23 pm
Down2TheC wrote:It's a very cold fanbelt. Well... it could be. Next time you start it up and hear that, give the gas a bump and see if it gets faster. If it does, it's a fanbelt and not a big problem. (you could spray some belt dressing or just wait for spring)
the does get a little higher when i pump the gas im going to take it to the dealer tomorrow to check it out hopefully they wont rape me
dishon22
Postby dishon22 » Sun Mar 04, 2007 1:19 pm
went to the dealer they said its probably the alternator belt or power steering belt
dishon22
