SolaraGuy.com • View topic - Sway Bar
Sway Bar
Sway Bar
Postby Gunga » Tue Mar 13, 2007 9:16 am
After 12 years of driving Miata’s I now have a 2006 Solaria SLE
Love the car, but hate the handing. Want to add a sway bar. Not interested in any spring/lowering options. Just a sway bar.
Have searched, but can’t find any RSB’s for the Solaria.
Any recommended suggestions?
Gunga
Postby ---CAMRAZY--- » Tue Mar 13, 2007 9:19 am
Try RSB.... and from TRD.
Postby Gunga » Tue Mar 13, 2007 9:26 am
Thanks, Did nlot notice there were multiple pages.
Gunga
Postby PXLpainter » Tue Mar 13, 2007 9:49 am
Welcome to SG - and welcome to Toyota! :D
There are hundreds of threads that talk about the RSB (Rear Stabilizer Bar) and FSTB (Front Strut Tower Brace) - both TRD products. The search as mentioned above will give you several pages on them and people's experiences with them (all positive, of course!) ;) Here's a currently active thread:
http://www.solaraguy.org/viewtopic.php? ... highlight=
The TRD RSB is the first recommended mod you'll want to do to your ride, hands-down. THis should have actually been put on the car in the factory IMO! Here's a few shots of mine installed:
Then for a more stabilized front end (takes out the nose-dive into tight corners) get the TRD FSTB - which takes about 15 minutes to install. Much more noticeable affects on the convertible too.
And lastly, something I'm going to check out soon, a front sway bar from Australia that's just emerged (but not tested yet by any SG member yet):
But to really make all this worth while, you'll eventually want to lower your ride as well. ;)
Good luck and don't forget to drop a line in the Introduction thread! :up:
Postby Sebas007 » Tue Mar 13, 2007 10:03 am
http://www.trdparts4u.com/MC-HGJ-EA.aspx
TRD REAR SWAY BAR 2004-2005 SOLARA
(Part #PTR02-06041-01)
it will fit your '06...I have it on my '06 SE V6
Postby kingkakyle » Tue Mar 13, 2007 5:00 pm
also i think if u put in solara rather than solaria ull egt more items ;)
Postby ---CAMRAZY--- » Tue Mar 13, 2007 5:05 pm
kingkakyle wrote:also i think if u put in solara rather than solaria ull egt more items ;)
get, its get.... if you wanna be anal about ish...... LOL!!!!! Let the guy try yo....
You know we all mispell on here, but for some its just normal. haha
Postby aziandanny » Tue Mar 13, 2007 6:59 pm
wat brand is that front sway bar?
aziandanny
Postby MCOjerry » Tue Mar 13, 2007 7:17 pm
It's in one of the recent posts...direct link to the site. If you search for front sway bar, you'll find it.
Postby kingkakyle » Tue Mar 13, 2007 7:28 pm
lol i know we all mispell, if anything i misspell almsot everything, just thought id point that out to him to help out in the future
Postby dronek1975 » Sun Apr 26, 2009 8:31 am
where can i get those front and rear sway bars at good price and how hard is the installation?....when i got my car used from the dealer i have noticed it has black bar mounted in the engine bay, above the engine. does it have to be installed at the shop or can be done by someone who can change oil and air filter by himself no problems?
Thanks
dronek1975
Postby Sparky5e » Tue Apr 28, 2009 9:13 pm
If you have general mechanical knowledge it can be done yourself. The front is very easy but the back is easier if you have a way to gat it off the ground.
I payed my mechanic $20 to put the stuff on (too lazy and he has a lift). Took him about 1/2 hr including having a drink and smoke afterwards.
07 SLE Convertable
Blue Streak Metallic
Sparky5e
Postby GzNutz » Wed Apr 29, 2009 5:35 am
Holy thread revival batman!
Postby panic » Wed Apr 29, 2009 6:54 am
The difference between the original and the TRD is huge - the effect of the bar is proportionate to the 4th power of the diameter, so (example only!) a 22mm bar is not 10% stiffer than a 20mm bar (22÷20), but 46.4% stiffer (22^4÷20^4).
Especially helpful in a convertible, since the body stiffness is much reduced by no B and C pillars.
panic
Postby PXLpainter » Thu May 14, 2009 6:33 pm
holyfuckinCRAP - two years later??? :o
For that you should have at least given some correct info.
1) There is no aftermarket FSB (Front Stabilizer Bar) for the Solara (trust me - I tried the Whiteline bar with a massive FAIL)
2) Only option up front is the FSTB (Front Strut Tower Brace) which is very different from a stabilizer bar.
Now let this poor thread go back into hibernation! ;)
Users browsing this forum: Google [Bot] and 14 guests
