SolaraGuy.com • View topic - adjusting right headlight
Postby Biggi_e » Thu Apr 05, 2007 2:44 pm
for some reason my right headlight beam is off and im trying to adjust it, my left one is adjust to beam as far down as possible. my right one WAS but i cant seem to get it to adjust like my left. any suggestions?
i did take the bulb out and put it back in and see if that helped in any way..but i didnt..
Postby cklinh » Thu Apr 05, 2007 2:54 pm
Aren't headlights designed to be adjusted differently?
i.e., so that the driver's side won't allow you to adust to be as high as the passenger's side? (so you don't blind traffic in the other direction...)
cklinh
Postby ---CAMRAZY--- » Thu Apr 05, 2007 4:22 pm
There is a opening through the engine bay where you can get to aim the lights what you are looking for is a Gear wheel (Looks like the pic), you stick a phillips screw driver in there and turn it clockwise for up, counter clockwise for down.....
Good Luck Eddie!!
Postby Biggi_e » Thu Apr 05, 2007 4:37 pm
milt, that exactly what i did. its like its "stuck" not sure..dont know what to do
Postby ---CAMRAZY--- » Thu Apr 05, 2007 4:57 pm
Are you adjusting the headlight in the dark?
Postby Sebas007 » Thu Apr 05, 2007 4:57 pm
Maybe if it stuck, it's because you reach the max or min height...doesn't it ?
Postby Biggi_e » Thu Apr 05, 2007 4:59 pm
Sebas007 wrote:Maybe if it stuck, it's because you reach the max or min height...doesn't it ?
it looks like it just doesnt want to move at all, up or down..
Postby Biggi_e » Thu Apr 05, 2007 6:42 pm
---CAMRAZY--- wrote:Are you adjusting the headlight in the dark?
i did it during the day and night. not much of a difference. ill try and figure it out tomorrow
