SolaraGuy.com • View topic - oil change and maintenance light.
Postby honky » Sat Apr 07, 2007 1:47 pm
2004 Solara SLE convertible
Well just did the first oil change on my car. Put in Mobil 1. Was not to impressed the way the filter did not drain all the oil out of itself and some ran out as I tried to get it off. Is there a trick to this ? Also, How do I reset the maintenance light which I assume is on because a oil change was needed.
Thanks
My wife loves the car. We bought it with 15,000 on it, just turned 19,000
honky
Postby **PoshPepper** » Sat Apr 07, 2007 1:52 pm
While the car is off press and hold the odometer reset while you turn the car on. Keep holding until the odo flashed all zeros and dashes. The light should then turn off.
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Light
Postby honky » Sat Apr 07, 2007 4:16 pm
Thanks Posh, and off we go.
honky
