SolaraGuy.com • View topic - A/C controls from analog to digital
Postby fulanodetal » Thu May 03, 2007 1:53 pm
Anybody try to upgrade the dial AC controls to digital?
If so, how much?
what mods?
easy install?
worth it?
fulanodetal
Postby NeFaRiOuS_SLE » Thu May 03, 2007 2:50 pm
Try doing a search next time... In case you didn't, I'll let you go this time but others may not be as forgiving:
It IS possible, but VERY involved as you have to install tempurature sensors, convert the electrical controls and a few other things... One person embarked on this project, but I never heard from him again.
Postby Gadgetjq » Sat May 05, 2007 5:48 am
It'd probably be simpler to trade for an SLE which comes from the factory with the auto climate control.
Cheers
Gadgetjq
Postby Astro » Sat May 05, 2007 8:41 am
I'd probably look into going to a junkyard and try to find an sle. Then, take out the climate control and look all the wiring. There's probably extra relays and sensors that manuals don't have. I would think after the relays/sensors the wiring to the fuse panel would be the same? But, it might be a little more complicated than that. I don't know anyone who's done this....you'd be the first if you can complete the job! :D If you can get it done, please make a tutorial.......
Postby Sentinel » Sat May 05, 2007 11:19 am
there are also going to be servos to control the amount of heat, and where the air goes. A junkyard car sounds like the best bet, because you'll need a bunch of stuff. It is far more involved than swapping the front panel.
Sentinel
Postby fulanodetal » Sat May 05, 2007 2:35 pm
Sounds like more work than I thought. I researched the digital panel and that was $500+(new) I rather put that money into something else like audio/video right now. I keep you guys posted if I do drop in the digital panel.
fulanodetal
