SolaraGuy.com • View topic - Where To Buy Replacement Fuses?
Postby Gadgetjq » Sat May 05, 2007 4:08 pm
Edit to update: The fuses used in our Gen2 Solara's (maybe Gen1) are, it turns out, called "Low Profile" Mini Fuses. You can see them on the LittelFuse Website here http://www.littelfuse.com/cgi-bin/r.cgi/en/prod_series.html?SeriesID=156&LFSESSION=LSU5rATSgB
Purchase them online here http://www.tessco.com/products/displayProducts.do?groupId=615&subgroupId=12&search=false&page=2
Trying to find these fuses at a standard auto parts store is next to impossible. After checking NAPA, Autozone, Pep Boys and Autozone I finally found a "variety pack" of 6 fuses for $5 at another Kragen but it was the only package they had.
If you're a tinkerer like I am you might want to lay in a small supply of these fuses because you won't find them on the dark and storm night or in the middle of nowhere when fuses tend to let go.
Cheers,
Gadget
_________________________________________________
Original Post
Help!
The under dash fusebox uses a tiny little odd shaped fuse Toyota shows in the owners manual as a "Type B". I can't find them in any automotive store locally (counter guys say "what kind of car you got again?" or even on the littelfuse website.
I suppose my Toyota parts department will have them (at a buck each) but where have forum members found replacement fuses?
Thanks,
Gadgetjq
Gadgetjq
Postby cklinh » Sat May 05, 2007 6:20 pm
I was able to find them at Kragen's...
cklinh
Postby SolaraBlue » Sat May 05, 2007 6:34 pm
are the gen2 fuses different fom the gen1? if not, advanced autoparts...auto zone, etc... should all have them... take a fuse from your car in as an example....
Postby cklinh » Sat May 05, 2007 7:54 pm
Yeah... they're just mini-fuses... if your auto parts store doesn't have them, you should think about going to a different one...
cklinh
Postby kingkakyle » Sun May 06, 2007 2:06 am
i just went to parts department....
i think i payed less than 1$ each, so i was like watever no need to go look
Postby Gadgetjq » Sun May 06, 2007 5:03 am
Thanks for the tips.
I tried Pep Boys, Autozone and Worldwide auto parts and all said they'd never seen (or stocked) a fuse like that.
I'll expand the search to Kragen and NAPA today.
Cheers
Gadgetjq
