SolaraGuy.com • View topic - maintenance light
maintenance light
maintenance light
Postby mluu510 » Wed May 09, 2007 12:34 pm
i just had my oil changed at mazda dealer. they forgot to reset my maintenance light, so it's on now. how do i reset it?
mluu510
Postby cklinh » Wed May 09, 2007 12:41 pm
Should be in the manual... don't have it handy right now though...
cklinh
Postby rollaevo99 » Wed May 09, 2007 12:48 pm
press the dimmer stick on your gauge and turn the ignition key at "on" position and wait until goes off.
Postby MrMikeL » Fri May 11, 2007 1:04 pm
"Dimmer stick" is also the thing you press to reset the trip odometer. In order to reset the maintenance light, be sure the odometer is on the total setting, not any of the trip settings, then depress the "dimmer stick" and turn the ignition switch to "on". You will see a series of dashes. Once they stop moving, it's reset.
MrMikeL
Postby mluu510 » Fri May 18, 2007 8:17 pm
thanks, guys.
mluu510
