SolaraGuy.com • View topic - ABS, VSC & TRAC OFF Lights are on........help.
Postby 06SLE » Wed Jun 06, 2007 5:46 pm
2006 Solara SLE Coupe V6. 9200 miles.
The ABS, VSC, and TRAC OFF lights are on. Any ideas? :cry:
2006 Solara SLE V6
2002 Tundra Access Cab SR5 V8
06SLE
Postby cklinh » Wed Jun 06, 2007 6:46 pm
I had the same problem, it's because the gas cap isn't on all the way (you need to hear three clicks).
Make sure it's on tight, then you either wait it out, or unplug the battery for 5-10 minutes.
I don't recall the exact directions, but that's close... it's in the manual, I think, so look there to confirm.
cklinh
Postby 06SLE » Fri Jun 08, 2007 7:24 pm
Thanks for the tip^^^^^^^
My wife took it to the dealer today. They said the ABS Actuator is bad. Warranty is covering it (of course), and we get the car back Monday.
2006 Solara SLE V6
06SLE
Postby RDKamikaze » Sun Jun 10, 2007 8:47 pm
I once left the gas cap out on accident. When I got home (not even 1/4 mi. drive), I noticed it and screwed it in. I never got any lights appearing.
RDKamikaze
Postby MrMikeL » Mon Jun 11, 2007 12:18 pm
I'm no expert, but those lights probably are not related to a loose gas cap. Your car is under warranty, so take it to the service department for a check.
MrMikeL
Postby Patrik » Mon Jun 11, 2007 1:46 pm
as my good asian friend Som Tin Wong would say... taking it to the dealer is the best thing to do.. let them take care of it :)
Patrik
Postby 06SLE » Mon Jun 11, 2007 8:18 pm
We got the car back today. All is well, no lights on and the brakes work fine. The dealership told my wife that they've seen a few of the ABS Actuators go bad, at least I'm not the only one........ :roll:
2006 Solara SLE V6
06SLE
