SolaraGuy.com • View topic - My Fog Lights Won't Turn On!
Postby RDKamikaze » Tue Jun 12, 2007 9:29 pm
Tonight, I was working on putting my old HID kit on my fog lights. I got different bulbs for the fogs, so I know that's not the problem. My normal fogs worked, and then I put the driver's side HID on and it worked. I put the passenger side HID on and it didn't. When I tried the driver's side on the passenger side, it didn't work. I put the driver's side HID back and it worked for a split second and then turned off. After going WTF?!, I then proceeded with trying to turn it back on. Nothing. I hooked up the old bulbs and turned them back on. Nothing. Did I short a fuse or circuit somewhere?
RDKamikaze
Postby hskrsolara » Tue Jun 12, 2007 9:47 pm
i hope this is not a sign of things to come...
hskrsolara
Postby RDKamikaze » Tue Jun 12, 2007 9:55 pm
Nope, I figured it out. It was just a blown fuse. I touched a wire to a place I shouldn't have on accident.
Where do I get these TINY fuses? I'm going to call Autozone in a second, but if you know where that would be open at 11pm :) let me know.
RDKamikaze
Postby cklinh » Tue Jun 12, 2007 10:05 pm
Did you check to see if there's an extra fuse or two in a slot that's not connected to anything?
cklinh
Postby RDKamikaze » Tue Jun 12, 2007 10:09 pm
Yes, I checked and double checked. I even considered stealing one from another function. I don't want to do that, though, because if it blows again I have 2 fuses I'll have to replace :(
Where do I get these little ones? does anyone know what I'm talking about? Should I take a picture of it?
RDKamikaze
Postby iinokturnolii » Tue Jun 12, 2007 10:13 pm
over here we have them at "napa" auto supply... dont know if you have them over in AZ.
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Postby RDKamikaze » Tue Jun 12, 2007 10:14 pm
I'll have to check with NAPA. I don't think it's a 24hr though :(. Looks like I have to wait a day, oh well.
RDKamikaze
Postby KSolara » Tue Jun 12, 2007 11:13 pm
yeah.. napas usually close early.. around 5
o4 SE I4 Lunar mist
KSolara
Postby sydemoid » Tue Jun 12, 2007 11:30 pm
24 hr place with car parts?
WALMART.... the only reason I loved that store....
they have the basic fuses there, or atleast should have.
sydemoid
Postby Sebas007 » Wed Jun 13, 2007 4:50 am
We all have extra fuses...check in your owner manual book.
Postby Gadgetjq » Wed Jun 13, 2007 6:27 am
RDKamikaze wrote:Where do I get these little ones? does anyone know what I'm talking about?
Covered here: http://www.gadgetjq.com/solara/fuse.htm
Cheers
Gadgetjq
Postby ArizonaEagle07 » Wed Jun 13, 2007 7:40 am
just a side note, whenever I mess with electrical on my car I always disconnect the battery. Just cause it saves you time and money in the end.
RIP: 2000 Toyota Solara SLE
ArizonaEagle07
Postby woa_its_j3ff » Wed Jun 13, 2007 9:48 am
ArizonaEagle07 wrote:just a side note, whenever I mess with electrical on my car I always disconnect the battery. Just cause it saves you time and money in the end.
+1.
Postby RDKamikaze » Wed Jun 13, 2007 10:58 am
Yeah, I made the mistake of not doing that.
Thanks for that little link, it helped a ton!
RDKamikaze
Postby RDKamikaze » Thu Jun 14, 2007 8:43 am
Alright everyone, I fixed the problem. I burnt out another fuse when I had both HIDs on direct connect (they drew more than 10A together), so I put them on the relay harness that I totally forgot I had. This made the current draw from only one light hookup, so they both drew less than 10A together to start the bulbs and warm up.
In short, if you're blowing fuses when you get your HID kit, use the relay! :)
I'll get pics up tonight when it's nice and dark outside. All I need to do now is figure out where to mount the ballasts.
RDKamikaze
