SolaraGuy.com • View topic - Where did my coolant go?
Postby HID04V6 » Thu Aug 02, 2007 3:56 pm
Took my ailing 04 Solara in for an oil change and 4 new tires. When I picked the car up, the service manager told me that there was no coolant in the container under the hood. They claim that they checked everything for leaks and did not see any coolant in the oil. I have a very hard time believing this- coolant can't just evaporate out of a sealed container. I have a feeling that it is somehow leaking into the engine through a bad gasket and Toyota is waiting for the car to run out of mfg warranty (64 days left) and then tell me it has a massive repair necessary. The car has 21,500 miles. I'm going to check it out myself, as much as I know about cars (which is very very little) and see if I can figure something out. Just makes no sense where that much coolant could go with no trace... Just another repair to add to the file for this car- so much for quality and reliablilty on this car- that was left at the factory.
HID04V6
Postby SC V6 » Thu Aug 02, 2007 4:12 pm
my car has almost never had coolant in the overflow container.. not sure why, but thats how my 99 is
SC V6
Postby HID04V6 » Thu Aug 02, 2007 4:24 pm
SC V6 wrote:my car has almost never had coolant in the overflow container.. not sure why, but thats how my 99 is
Mine has always had coolant in it, as does my girl's Nissan Murano and my other car. I am a bit confused and irritated with the car at this point.
HID04V6
Postby LatinDragonXJC » Thu Aug 02, 2007 5:29 pm
Same here, I just noticed that in my '00
LatinDragonXJC
Postby Jai_Jai_Binks » Thu Aug 02, 2007 7:01 pm
something is wrong with the hoses or the seals. The resivor is there for a REASON. both my 5sfe and my 1mzfe have coolant resivors' which are filled with coolant. Not empty. Fill it up and take it for a spin with a friend behind you..see if your exhaust pipe is leaking it out from there..thats what happened in our ES.
Mine was low too
Postby lambition » Sun Aug 26, 2007 6:58 pm
My coolant went below low level indicator as well.
I suspect water might have evaporated from reservoir tank, since it is not completely sealed.
Same thing happend to my mother's Highlander.
I just filled up reservoir with 50/50 mix of coolant.
If water evaporates enough, and level goes below pipe that is connected to reservoir cap, it may cause air to enter cooling system while engine cools since it cannot suck coolant back.
lambition
Postby DevilzAdovocate » Sun Aug 26, 2007 7:15 pm
how do you have 21,500 miles on it barely? on a 04? has the car been sitting on a lot the whole time?
DevilzAdovocate
Postby NeFaRiOuS_SLE » Mon Aug 27, 2007 11:31 am
Very bizarre indeed... Top it off and try tracing the origin of it... My car has 108K miles on it with a new water pump as of 102K and only needed to add about 1/2 a cup of water ever since; keep in mind I live in Southern Cali and use the A/C religiously, and the average water pump lasts about 90K miles.
Postby HID04V6 » Tue Aug 28, 2007 3:49 pm
DevilzAdovocate wrote:how do you have 21,500 miles on it barely? on a 04? has the car been sitting on a lot the whole time?
I bought the car brand new with 250 miles in 2004. The car hardly gets driven. It has spent a good portion of its life sitting at Toyota for its problems. Each time that I drive it, something seems to go wrong and need repair. It has left me stranded many different times because it breaks down. I ordered a new car to replace it, because the car has 35 days of warranty left, then i'm 100% out of luck. Its up to 22,000 and coolant is nowhere to be seen. Toyota told me that they are "too busy" to look at the car for the next couple of weeks- (trying to screw me over because they know it only has 35 days of warranty left- so they'll look at it in 45 days, out of warranty, and then tell me it needs a new engine or some major repair.) I am honestly scared to drive the car after it runs out of warranty, because I don't want to be paying $$$$ for tons of repairs on a poorly made vehicle.
HID04V6
Postby philosophicaljt » Tue Aug 28, 2007 5:49 pm
put some cardboard under the engine when you park your car. In the morning, check to see if there are any spots.
2004 Solara SLE V6
Search
philosophicaljt
Postby Gadgetjq » Wed Aug 29, 2007 5:52 pm
HID,
On the contrary, the overflow container is 'not' a sealed container and coolant 'can' evaporate (it's 50% water after all).
Coolant is one of the items on your maintenance checklist to be checked and adjusted (topped off if necessary) periodically. Coolant level is specifically mentioned for the 15,000 mile maintenance but it should really be checked at least every oil change along with brake fluid and other liquid condition/level.
Gadgetjq
Postby HID04V6 » Thu Aug 30, 2007 1:19 am
Gadgetjq wrote:HID,
Thanks for the info.
I have gone aprox 700 miles and the coolant container is empty again- I should not have to add coolant to the car every 700 miles.
HID04V6
Postby Gadgetjq » Thu Aug 30, 2007 4:05 am
HID04V6 wrote:I have gone aprox 700 miles and the coolant container is empty again- I should not have to add coolant to the car every 700 miles.
Wow, that's information that throws a whole new wrinkle into the discussion.
Time for a compression check to see if that coolant is finding its way into one (or more) of the cylinders.
Cheers
Gadgetjq
Postby Down2TheC » Sat Sep 01, 2007 10:02 am
At that low mileage, if there is a problem it's probably a loose hose clamp or something simple at least. Doubtful that you'd be burning it and have an impending head gasket issue.
Down2TheC
Postby HID04V6 » Sun Sep 02, 2007 3:48 pm
Down2TheC wrote:At that low mileage, if there is a problem it's probably a loose hose clamp or something simple at least. Doubtful that you'd be burning it and have an impending head gasket issue.
Its on the list to check out when it is towed to Toyota on Tuesday. It is currently sitting in my driveway and won't start. It went through this earlier today and once I did get it started, I got a check engine, VSC and TRAC OFF light. One thing after another.....
HID04V6
