SolaraGuy.com • View topic - All my warning lights turn on when I start the car?
Postby RDKamikaze » Wed Aug 29, 2007 1:38 am
Ok, at first I thought this was just a little fluke that happened every once in a while. For the past two weeks, my warning lights (e-brake, tire pressure, and another) would just turn on random times that I turned my car on. To fix it, I would turn teh car off and back on. Ususally, the lights would go away after that. Now, this problem is occuring almost every time I turn my car on! What's going on, is that some sort of code that I don't know yet?
Also, for the first time, my speedometer wasn't working when the lights all turned on once! I stopped off the side of the road, turned my car off and on, and it worked fine again. Other problems during these lights being on include my car being in neutral when it's in reverse (I hit the gas and nothing happens) and SLOW accelleration.
Has anyone else had this problem yet? I'm trying to figure out why my poor baby is freaking out on me, but I can't come up with a conclusion!
RDKamikaze
Postby Gangis » Wed Aug 29, 2007 9:02 am
It sounds like an electrical/computer problem to me. :( BTW - sorry I didn't respond to your IM. I was sleeping. Remember, there's a 3 hour difference between us. :)
Gangis
Postby **PoshPepper** » Wed Aug 29, 2007 11:56 am
I think you need to take it to a mechanic... my guess is electrical/alternator issues.
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby Turbosolara » Wed Aug 29, 2007 12:09 pm
i hope you still have warranty. if not, try to reset ecu and see if that helps
Postby Gadgetjq » Wed Aug 29, 2007 5:32 pm
I think the car is pissed because you're trying to sell it. Machines know these things...ya know? :D
Actually it sounds like you have a faulty electrical connection, probably a ground. I'd start with the battery even though your car is starting ok.
Disconnect both terminals (ground first) and clean both the battery and cable side throughly then reconnect. That one simple thing can frequently fix mysterious electrical troubles.
If that doesn't work you're going to have to chase after a bad connection.
Cheers
Gadgetjq
Postby RDKamikaze » Thu Aug 30, 2007 1:46 am
The first problem I came up with as well was a bad wiring or ECU connection to ground, and that's what a few other people agreed to. I'm hoping all I need is to fully charge my battery (I think I left my inside lights on one night) or even get it replaced. It's just weird how this problem can just appear out of nowhere from any other reason, yeah?
RDKamikaze
Postby boaclub923 » Thu Aug 30, 2007 11:21 pm
hum, i get the same problem twice!!
but.. thx god.. turn off engine and wait alittle bit, everything back to normal..
somehow.. i feel like it has something to do with heat...
cause, i park the car under sunlight both time when it happened.
boaclub923
Postby RDKamikaze » Fri Aug 31, 2007 8:14 am
The problem occurs for you with parking in the light? Weird, because I'm noticing that it happened ONLY at night yesterday. In the day time, it was perfectly fine and the CEL went away, but then once night hit, bam! There were all the hazards and the CEL again. I just noticed it yesterday, so I'm not sure if it's a pattern yet.
Input on that?
RDKamikaze
Postby [SMAN] » Fri Aug 31, 2007 8:29 am
IF the CEL light comes on, take it to autozone or whatever and have them read the codes. Let me know what hte code is and i'll tell you what the manuals say to do about fixing it.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby Down2TheC » Fri Aug 31, 2007 9:48 am
Battery, then batt connections, then alternator, then mechanic.
Down2TheC
Users browsing this forum: Google [Bot] and 12 guests
