SolaraGuy.com • View topic - auto heating and a/c controls
Postby data xXx » Sun Sep 23, 2007 2:28 pm
I was wondering, if i have the manual hvac controls on my lara (3 knobs) can i just plug in the auto one (buttons) and have it work? or would i need something extra internally?
data xXx
Postby [SMAN] » Sun Sep 23, 2007 4:41 pm
The plug is physicly different.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby MCOjerry » Sun Sep 23, 2007 5:29 pm
In order for the auto climate control to work, you would also need the sensor on the dash.
I don't know if they are really different as far as size and fit go, but the sensor on the dash is needed.
Postby data xXx » Mon Sep 24, 2007 1:30 am
well, if its that much of a burden, i guess i WONT be trying out my lil ghetto experiment, thanks for the answers guys!
data xXx
Postby philosophicaljt » Mon Sep 24, 2007 4:21 am
yeah, there is more to it than one might expect. There are two sensors, new wiring, and you have to change your ECU iirc, but I can really check ino that later if you really care.
2004 Solara SLE V6
Search
philosophicaljt
Postby MCOjerry » Mon Sep 24, 2007 4:43 pm
philosophicaljt wrote:yeah, there is more to it than one might expect. There are two sensors, new wiring, and you have to change your ECU iirc, but I can really check ino that later if you really care.
Where's the 2nd sensor?
Postby philosophicaljt » Mon Sep 24, 2007 9:07 pm
The one by your knees?
2004 Solara SLE V6
Search
philosophicaljt
Postby [SMAN] » Tue Sep 25, 2007 7:51 am
Well, i looked things over, and it's a but puzzleing, but yeah it's a lot more work then you'll probably want to do. From what i can tell, there are 3 different types of climate controles. The manual version (rotary dials) seems to be the same for both the 4 and 6, however, the automatic seems to have different plugs based on if you have the 4 or 6, it also has the amplifier built in. this means that you will need to get all new wiring harness (allthough it is possible to rewire MOST of the pins) but the amount of work would really make this cost prohibitive except for the most die hard of fans for this mod.
2004 Solara V6 SE
1996 Camry I4
[SMAN]
Postby MCOjerry » Tue Sep 25, 2007 5:33 pm
philosophicaljt wrote:The one by your knees?
Postby harp00n » Sat Sep 29, 2007 4:31 am
Is it possible to make A/C don't start when I select "legs/window" or "window" modes (I have manual controls)?
Will it start in winter, if the temperature is low?
harp00n
Postby MCOjerry » Sat Sep 29, 2007 10:28 am
Can you explain that a little more?
Postby harp00n » Mon Oct 01, 2007 11:30 am
Well, when I set wind flow to "window" or "legs/window" - air conditioning starts.
And I don't want it to start, because i don't need a/c all the time in this directions of wind flow.
p.s. excuses for bad english :)
harp00n
Postby data xXx » Mon Oct 01, 2007 1:11 pm
I dont think that can happen:
having the a/c off when the window/legs function is on because the windshield defroster uses the a/c
data xXx
Postby MCOjerry » Mon Oct 01, 2007 6:38 pm
harp00n wrote:Well, when I set wind flow to "window" or "legs/window" - air conditioning starts.
That's strange, it sounds like you have some sort of crossed connection.
Will the AC turn off, but fan stay on if you push the button?
Postby harp00n » Thu Oct 04, 2007 7:48 am
A/C button does not turn on, when i choose these 2 modes, so I can switch it on (the light turns on) and then off (the light turns off) but A/C works anyway.
harp00n
