SolaraGuy.com • View topic - Gen 2 Center Flip Top
Postby radmanGTO » Sun Sep 30, 2007 2:22 pm
Well, I thought I had "lost" 2 pens over a short period of time. Recently, I tried to open the flip lid to put a cup in the largest part of the holder and found the lip would not open fully. Upon the usual investigation, I find that the two wayward pens somehow got behind the opening and were "there" stopping the full open swing of the lid.
I've tried wedging the lid slightly and fishing out the pens with anything and everything; no luck.
Anyone have success "finding" your pens or other items in that black area? Worse case in removing the center consol but that would seem like a huge job ....
Thanks,
Radman
Radman
'06 Artic Frost Pearl Solara SLE
Michael T's Combo Grilles,
Gold Pkg, sills, curtains, NAV, VSC, TRAC
radmanGTO
Postby [SMAN] » Sun Sep 30, 2007 4:51 pm
if your talking about the cup holder inbetween the center glovebox and the shifter, it's easy to get that out. Just open the bottom part of the two layer glovebox, and then start prying the forward part up and it just pulls right out. check my pictures of my GPS install to see how.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby radmanGTO » Sun Sep 30, 2007 6:45 pm
If your caption on your photo is correct, it's just prying up and out it pops ....??
"The center console just pops out. Start by prying up at the rear glove box and work your way forward"
No clips, screws, etc,....??
Thanks,
Radman
Radman
radmanGTO
Postby [SMAN] » Sun Sep 30, 2007 6:48 pm
yup
2004 Solara V6 SE
1996 Camry I4
[SMAN]
Postby PhreakdOut » Sun Sep 30, 2007 10:03 pm
I agree, it's pretty easy. You will be surprised.
Postby PXLpainter » Mon Oct 01, 2007 5:49 am
^^ Even easier if you use a crowbar and tap on it with a mallet! :D
Postby radmanGTO » Mon Oct 01, 2007 5:18 pm
That's a real "leap of faith" just grabbing your consul and prying it up ... man, that just doesn't seem like it should work .... !!!!
But, I'll give it a try ...
Thanks,
Radman
Radman
radmanGTO
Postby radmanGTO » Tue Oct 02, 2007 6:31 pm
OK ... so I was quite skeptical ... :>))
Yoi .. double yoi ... how friggin easy it was ... I just started to lift up on the emergency brake end, and .... it came up so-o-o- easy .... and ... went back together so easy ... !!!
Thanks all ... got those pens out and ditched them ... :>))
Radman
Radman
radmanGTO
