SolaraGuy.com • View topic - No Start
No Start
No Start
Postby HID04V6 » Mon Oct 01, 2007 5:00 pm
I've had a ton of problems with my 04 Solara not starting. There are times that I can turn the key and it will just crank and crank. 23,000 miles and about 20 times to the shop, it finally threw some codes in the computer. The check engine, vsc and trac off lights were all 3 lit simultaneously. What Toyota tells me is that the code they pulled, which was not "active" said that "All 6 ignitors failed". Well, they won't do anything about it to fix it, as they said the code isn't "active" anymore. They also said they can't just throw parts at it to try to fix something that they cannot figure out how to duplicate.
Any suggestions as to what would cause all 6 ignitors to fail, or what could possibly be done to make them all fail again so that I could get this irritating problem fixed? If my new car wasn't 5 months away, I wouldn't care, but I'm down to 20 days of warranty and a bunch of dealerships that don't want to touch the car.
Thanks for any suggestions.
HID04V6
Postby Somedude » Mon Oct 01, 2007 5:43 pm
Your Solara is a lemon, why didn't you turn it in for a different car earlier?
My car has less than 20k in miles but I never had any problems with mine, except the time that the passenger side power window had problems but I got that fixed under warranty.
Somedude
